Window Monkey 1.3.1 English
Download: http://archive.info-mac.org/cfg/window-monkey-131.hqx
This is the English version of Window Monkey 1.3.1.
Window Monkey adds background pictures or textures to any window in the
Finder -- it's like "Desktop Patterns" or "Desktop Pictures", but for
folder window backgrounds instead of the desktop.
You can color-code your windows to see at a glance what they contain, or
use wild patterns just for fun. Give your folder of "work stuff" a
background that looks like a legal pad, or choose a background of hearts
for that Zip disk full of love letters.
This program also helps you better manage your windows in every
application (not just the Finder): You can use the handy Window Monkey
menu to quickly go to any window in any application, even if it's buried
beneath many other windows. Window Monkey also remembers recently used
folders and lets you instantly jump to any open or recently used folder
from an Open or Save dialog box.
Over 60 background patterns are included, and you can add as many as you
wish by simply pasting or dragging your own pictures into the control
panel.
Version 1.3.1:
- works around a problem in Mac OS 9.1 that caused a conflict with
PopChar
- fixes a conflict with recent versions of GraphicConverter
- the "background Finder window click" feature can now be turned off
or assigned a key combination
- more than a dozen new patterns are included
Window Monkey is compatible with System 7, Mac OS 8 and Mac OS 9
(including 9.1).
$19.95 shareware. A Japanese version is also available.
