slide show woes; and solution
Path: utzoo!watmath!clyde!cbosgd!ulysses!mhuxr!ihnp4!houxm!vax135!cornell!uw-beaver!info-mac
Subject: slide show woes; and solution
Date: Thu, 7-Feb-85 07:06:30 EST
Article-I.D.: uw-beave.797
Posted: Thu Feb 7 07:06:30 1985
Date-Received: Fri, 8-Feb-85 07:02:48 EST
Lines: 55
At Stanford we use a video projector at our user group meetings
to show new programs and give "Mac slide shows". Some people have
been using the Magnum Software "Slide Show Magician".
In fact I was using (or trying to use it) in front of our group
recently, and was quite embarrassed when it totally refused to read
the "script" for my show. The same disks that failed on the demo
machine, worked fine on three different Macs back in my office.
What gives?
Well I discovered this: as a "feature", the Magnum Software puts
bad sectors on your nice clean disks. They record special copy
protection sectors on top of your script file whenever you "save" it.
This is bad design, but it usually works. However if you are using
a different machine for the final demo, and it happens to have
a very slightly out of spec disk drive, you can kiss your presentation
goodbye. Apple II users will recognize these problems, I'm sure;
the copy protection schemes in use there are in some cases very
disk drive dependent.
At any rate, here's my solution: the C source and binhex binaries
for a very simple and easy to use "slide projector". It is called
"slide".
It uses the same "slide format" as the Magnum program: just simple
MacPaint documents. There is a template provided called "slideblank"
that you should use as a guide in positioning your material. Basically
your pictures must be in the upper left corner of the MacPaint
"physical page". "slideblank" has the four rounded screen corners, and
two off screen lines to show you the limits of this area. Be careful
not to move these bits on the physical page (you can move the viewing
window, but don't move the actual page dots in "show page" mode).
"slideblank" also has a single dot positioned where I usually start
the first line of my text or graphics. I found the grid lock mode
very handy for lining up the blocks of text.
The slide order is determined by the MacPaint file names. Only one slide
show can be stored per disk. The file names have the form "NumberName",
for example "1title", "2overview", "3goals", etc. Only the number
part of the file name determines the slide order. You can use numbers
as large as you like (16000 max); I suppose basic fans might number
their slides 10, 20, 30, etc. You can also use fractions to "insert" slides,
e.g.: "1.2credits". You could set the numbers at the time of creation
with MacPaint, or go back latter with the Finder and touch up the
slide ordering.
The mouse can be used to sketch on the screen. Spacebar advances
to the next slide. Backspace reverses.
--Bill Croft, SUMEX project, Stanford Univ.
[Stored on as slide.shar (C source), slide.hcx (program)
and slideblank.hcx (blank slide)]
