Update from 4.2 Beta 2 to Beta 3 failure?
Hi there, anyone experiencing the same issue? I am on the latest official release of iTunes, but it keeps refusing to update - it says something like "your device is not compatible" error. Tried it on both, Mac and PC, but failed...
Re: Update from 4.2 Beta 2 to Beta 3 failure?
It probably has something to do with using a beta
you might want to ask on Apple's dev forums as you're not *supposed* to discuss the betas publicly per the contract you signed anyways!
Me personally, I just wait out the betas and install the final releases even though I'm a developer.
davidklose13
- 2 MB
I'm experiencing the same issue. As per i think you have to use your older version till the final beta version of it comes finally.
iphone4
Thanks for reply. I'm not a developer - my friend who is added my iPad's UDID on his account. I begged him to do so as I wanted multitasking and my country's (Czech) keyboard.
Could it be a mismatch of language translations?
