Using projector
NoticiasIdiotas
Using projector
Post by NoticiasIdiotas »
Hi,
So, i have to present a presentation in class next week and I tried connecting the projector to my MacBook pro this week, just to see if it worked or if i needed something else...
The thing is, when connected, the image was apl. Yellow
NoticiasIdiotas
Re: Using projector
... The image was all yellow-ish... I was just wondering if There is an automated way to configure the image when it starts projecting...
Thanks
wove
Re: Using projector
Post by wove »
I would first check with the documention for the projecter to see if there is anything special in how color calibration is handled. The manufacturer of the projector may have a color sync profile available which would correct color problems. In the old days of movie projectors, bad color was often a function of having a bad/wrong bulb in the projector.
The projector should show up as a display in the Displays preference panel, part of the System Preferences a menu item in the Apple Menu. If you select the color tab in the preference panel you should be able to calibrate the projector to get a better image and will have the opportunity to save the calibration for re-use.
\/\/i||i@m ()\/e
