ArraySync with 3 mac minis over the network
Mazze
Postby Mazze » March 20th, 2015, 6:17 am
Dear NaSoLab-support and arraysync community,
i need your help! I want to use 3 mac minis with 6 screens. Each mac mini has 2 of them connected. Mac mini 1 runs the server and the other 2 are clients. They are all connected by LAN and can find the server without any problems.
My video file was set up accordingly. (Made with keynote in 2560x2160) 2 wide - 3 high 1280x720 each
Questions is: How do i get my video spanned over all 6 screens? Do i need to split them up and put the split files onto each mini? How do i do that without "ArrayShaker" since it's not available anymore?
Thanks in advance :-)
Re: ArraySync with 3 mac minis over the network
Postby Turboladdade » March 20th, 2015, 7:24 am
You can do this with just one video file. First you want to set ArraySync into spanned mode. Then drop the video file into ArraySync on each machine.
For our purposes let's label each Mac Mini as 1, 2 and 3, and connect your six displays as follows:
[1][1][3]
[2][2][3]
Make sure in System Preferences, they're arranged properly (side-by-side on Mac Minis 1 and 2, stacked on Mac Mini 3).
Now, on all three machines, enable the Offset feature. If you have HD1080 displays (1920x1080) your offsets will be as follows for each machine:
Mac Mini 1:
Right: 1920
Bottom: 1080
Mac Mini 2:
Top: 1080
Right: 1920
Mac Mini 3:
Left: 3840
These numbers create an virtual extension of each Mac's desktop space to compensate for the other displays. ArraySync will then stretch and crop the video accordingly. If your displays are some other resolution like 1280x720 you'll have to redo the math accordingly:
Mac Mini 1:
Right: 1280
Bottom: 720
Mac Mini 2:
Top: 720
Right: 1280
Mac Mini 3:
Left: 2560
Please let me know if this makes sense or if you need any further clarification. Thanks!
Mazze
Postby Mazze » March 20th, 2015, 12:59 pm
Thanks for the quick reply and the explanation. It's working now (even if the video is stuttering sometimes, gonna play with video settings a bit to tweak it)!
Got the following setup:
[1][1] = 2560 * 720
[2][2] = 2560 * 720
[3][3] = 2560 * 720
Which is 2560 * 2160
While 1,2,3 are mac minis. Screens are samsung with a thin border.
Wouldn't it be better to just split the videos to save "bandwidth", since 2/3s of the video aren't needed?
Anyways, it's an awesome app with brilliant support. I'll recommend you wherever i can!
Have a nice weekend. Greetings from overseas :-)
Postby Turboladdade » March 20th, 2015, 2:46 pm
Mazze wrote:Thanks for the quick reply and the explanation. It's working now (even if the video is stuttering sometimes, gonna play with video settings a bit to tweak it)!
Try using Apple Intermediate Codec for video and AAC for audio. Might work better than H.264 if that’s what you’re using (H.264 is extremely resource intensive).
  • Similar Topics
    Replies
    Views
    Last post
Return to “ArraySync”
Who is online
Users browsing this forum: No registered users and 2 guests
