I just downloaded arraysynch and i'm trying to synch 2 separate videos of equal length using a macbook pro (though i will switch to a mac mini eventually).
how do I do this? its only letting me play 1 quicktime on two separate monitors, but i need to play 2 different files on 2 monitors, off one player. make sense? can arraysync do this?
synching 2 quicktimes
mariahgarnett
- 1 MB
Re: synching 2 quicktimes
Yes, ArraySync is made just for this. Set ArraySync to Standard mode and drop each video file onto the particular display you want do see it on, then start the server.
If you haven’t done so already you need to disable spaces.
