$tock¢omp v1.0
$tock¢omp v1.0
Download: http://archive.info-mac.org/app/bus/stock-comp-10.hqx
$tock¢omp is a simple, yet effective tool for doing all kinds of backwards
calculations regarding stock purchase scenarios. It was designed to quickly
help determine all kinds of information about making or evaluating a stock
trade. It allows you to store saved setups with the click of a button and
also will retrieve stock quotes from the internet and immediately calculate
them right into the fields of interest (quotes are delayed 15 minutes).
Another nice feature of $tock¢omp, is that it can switch between performing
LONG and SHORT position calculations at the click of the mouse.
Want to know what the target price of a stock needs to be in order to reap a
5% return? Set the target on "Total Return %", type in 5, hit your TAB key
and all the data updates telling you exactly where the price needs to be and
what the exact profit will be. If shorting a stock, you can quickly find out
exactly what your profits (or losses) are going to be in certain scenarios
by setting the TARGET switch and SOLVE switch accordingly and seeing the
result the moment you TAB.
A built-in stock fractions table lets you perform at-a-glance conversions
between dollar amount share prices and stock fractions in 1/64 increments by
simply hitting Control-F (win) or Command-F (mac). With a click of your
mouse you can copy and paste the fractions from the conversion table right
into your field of calculation. No more manually typing in the long decimal.
$tock¢omp has 8 built-in "Quick Click" stored settings buttons. These
quickly allow you to save your current values for a scenario, enabling you
to input other values for perhaps another stock, yet giving you the ease of
returning quickly to your previous scenarios without having to re-input all
the data and settings again.
SYSTEM REQUIREMENTS
MAC:
Apple Macintosh or compatible with a PowerPC, 68020 or greater processor,
using Mac OS 7.5 or later.
An internet connection via a modem, cable, DSL, etc. (needed only for "Quick
Quote" button)
