Hynoptic FAT
Hynoptic FAT
Download: http://archive.info-mac.org/app/ss/hypn ... at-201.hqx
The mad, acid, savescreen of your choice, is here againg! HypnOptic becomes
HypnOptic Savescreen System, a modular and customizable package that,
better than before, will drive you crazy.
The HypnOptic INIT automates the savescreen starting and the HypnOptic
Control lets you select your favoured module, the idle time and decide
whether the module should play sounds. Furthermore the Control accepts, as
module, any kind of file so it may launch, after the inactivity time, the
file you want: different savescreen applications, disk defragmentation
utilities, the letter you're writing, since one year, to your sweetheart
and so on.
Modules are stand-alone applications so, if you want, you may use them also
without the Control-INIT aid (just like the old HypnOptic), moreover any
module is able to play sounds asynchronously.
Besides INIT and Control, the HypnOptic Savescreen System package contains
four modules:
- HypnOptic Classic, the first, original version of the savescreen
responsible for, always living, HypnOpticmania.
- HypnOptic Standard, based on Classic version with some additional graphic
element. It may, casually, use RGB Colors and patterns, in addition to
Classic QuickDraw.
- OloPpat, it use patterns for creating a simple, but nice, savescreen.
- Sixties, a totally new savescreen with a psychedelic feeling...
Last, but not least, you may find inside the package a SDK for developing
your own savescreen application. The SDK project lets you concentrate only
on the creative part of developing: the main, and more tedious, part of
work is already done. Even if you're a inexperienced programmer you may
easily build your own HypnOptic, stand-alone, module. The SDK contains also
a fifth savescreen: HOSDK.
HypnOptic Control is Internet Config and Navigation Manager aware, moreover
it's Appearance savvy.
Author: Rocco Moliterno
mailto:[email protected]
http://yellowsoft.tsx.org/
HypnOptic page:
http://www.geocities.com/SiliconValley/ ... optic.html
What's new in 2.0.1 version
Added Registrations folder. Added Support folder. Graphic inside Control
window. Addresses update. Optimized code of all HypnOptic's objects.
Removed registration form.
