A Better Finder Rename 2.2.1
Download: http://archive.info-mac.org/disk/a-bett ... me-221.hqx
ABSTRACT
A BETTER FINDER RENAME
"A Better Finder Rename" is a contextual menu plugin for the Macintosh
Finder which allows users to quickly rename multiple files. "A Better
Finder Rename" is ideally suited for Macintosh webmasters, users who need
to transfer files from or to Windows or Unix, as well as for all other
Macintosh users who deal with large numbers of files.
Feature list:
* interactive/ automatic modes
* create numbered lists (e.g. image1, image2, image3, etc.)
* replace anywhere in the file name
* replace at the beginning of the file name
* replace at the end of the file name
* add at the beginning of the file name
* add at the end of the file name
* convert to uppercase
* convert to lowercase
* remove characters at the beginning of the file name
* remove characters at the end of the file name
* examples for each mode
* all settings are "remembered" from one usage to the next
* fully integrated with the Macintosh Finder
For more information, as well as a demonstration of ABFR, please visit:
http://www.publicspace.net/ABetterFinderRename/
___
SYSTEM REQUIREMENTS:
A PowerMacintosh with MacOS 8 or later.
