Find Stuff version 2.0.3
Download: http://archive.info-mac.org/disk/find-stuff-203.hqx
Program to find files that have been misplaced on mounted volumes. Can
find by partial file name, date created/modified, type, creator, size,
get info comment, content and finder flags.
Multiple searches can run at the same time with the Thread Manager. The
ability to save the find parameters and use them again later. The
ability to save and print the find results for later reference.
Dave Sugar
