Download: http://archive.info-mac.org/disk/gsu-stpdemo.hqx
Shane the Plane 2.0.2 - file and font attribute editing utility.
Interactively or in Drag & Drop batches, permits you to change the
Creator/Type of files, their created/modified dates and times, a
host of significant Finder flags, plus a lot more. Makes files
invisible/visible, makes fonts behave like files by removing their
BNDL resources, batch "pastes" custom icons, intelligently renames
and/or "slugs" files, et very cetera.
Fully-functional demoware version. Includes registration software.
This archive replaces earlier versions of GSU-STPDemo.sit.
