RetroMail is an AppleScript application which enables you to have Eudora
email you a report from Retrospect upon success or failure of a back up.
It's main benefits are ease of set up and recipient maintenance, early
detection of back up strategy failure due to mechanical, media or logistic
problems as well as potential for off site IT monitoring. This is an
addition to the Retrospect Event Handler provided by Retrospect.
John Simmonds
CyberKare Technologies Inc.
(416)991-8514 www.cyberkare.com [email protected] [email protected]
