Screen Fortress
Screen Fortress
Download: http://archive.info-mac.org/disk/screen-fortress.hqx
Daniel Gagner
Tools for Teachers
Freeware
Needs an 040 or greater mac.
Screen Fortress is a bit less than a fortress but nevertheless it does
provide a way to stop someone for prying into your computer without a
little effort.
Installation: Drag the folder to your hard drive after unstuffing.
Double click on either file (they should stay in the same folder to
work) to start.
You can place it or an alias of it in your startup folder to lock the
computer at startup if you have a server or other computer needing a bit
of security.
Screen Fortress is simply a bound Filemaker Pro document. It puts
nothing in your system folder and as such shouldn't affect anything. You
don't need Filemaker Pro to use it.
I have included the unbound version of screen fortress. I do this in
case someone would like to see the simple database programming. This
part will not work without Filemaker though.
