speed-search-68k-11
speed-search-68k-11
Download: http://archive.info-mac.org/disk/speed- ... 11-68k.hqx
SpeedSearch is a shareware application that searches files for text. Using
the WASTE text engine, search results are displayed in the font and color
of your choice, and the number of results you can display is only limited
by available memory. SpeedSearch uses an optimized search engine and is
highly customizable. Anyone who needs to find text in files quickly and
reliably will find SpeedSearch very useful.
