Update-Virex Definitions is an AppleScript that does exactly what it
implies. It mounts the server volume, takes the Virus Definitions file
from a server volume and places it in the Virex Preferences folder on
your computer and unmounts the server volume. It will check the
creation date of the new file and compare it to the creation date of the
current Virus Definitions file. If they are different, the new file will
replace the older one. If they are the same, it will stop.
