Download: http://archive.info-mac.org/disk/wrapper-203.hqx
MediaWrapper Light lets you scan a removable disk, and print out the
contents on a wrapper that you can insert into the disk case. Currently
MediaWrapper Light supports Zip, Jaz, CD-ROM, EZ Flyer, SyJet, SyQuest,
MagnetoOptical Disks, and SuperDisk.
Changes for MediaWrapper Light 2.0.3
* Added support for SuperDisk Drive
* Added 25 character text limit for MO and Superdisk to prevent text overlap.
* Fixed print problem which sometimes clipped the end off the printed page.
MediaWrapper Light Features
MediaWrapper Light offers the following features:
* Scan inside subfolders
* Prints Date Scanned and Space Available on disk
* Editable fields
* Picture can be changed for all wrappers.
* MediaWrapper Light stores all settings including a default picture which
can be set using the Preferences in the Edit menu.
* MediaWrapper Light is also much faster then previous versions.
MediaWrapper Light was created using REALBasic, and no longer relies on
Applescript. In addition to a significant speed boost, MediaWrapper Light
does not experience any of the incompatibilities with HP 600 and 800 series
printers which were found in the previous wrapper programs. MediaWrapper
Light also eliminates the -1757 "Unknown Dialect Error" and the "Please
locate the Facespan extension" error, which occasionally caused problems
with older versions.
If you encounter any other problems with this software please report them
to me so I can fix them.
John Clark
[email protected]
MediaWrapper ©1998 by John Clark All Rights Reserved
MediaWrapper was created using REALBasic
For information on REALBasic go to: http://www.realbasic.com/
If you want to include this on a CD compilation, please inform me first.
