TimeSlice 2.6
TimeSlice 2.6
Download: http://archive.info-mac.org/app/time/time-slice-26.hqx
TimeSlice is an easy-to-use time-tracking and billing applications for
Mac OS 8.6 through Mac OS X. TimeSlice is used every day by small and
large businesses, consultants, and contractors to track billable time
spent on clients, business projects, specific jobs and more!
TimeSlice requiers CarbonLib 1.4 or newer when running in OS 8 or 9.
CarbonLib is free from Apple and can be updated by using your Software
Update control panel.
TimeSlice Partial Feature List
- Start, Stop, Pause, Resume, and Restart time records
- Direct In-line text editing in the main window time table as well as
using the Edit Time Record window.
- Expense column which stores a currency amount with each Time record.
- Sort time records by clicking on the column titles.
- Budget feature to keep track of cost and /or time against a budget
amount.
- Find and mark time records by date, category, client, and project.
- Project, Category and Client columns
- Pop-up menu for quickly selecting a client/project/category.
- Cut, Copy, Paste, Delete Time records
- Set the default values for a new Time Record
- Print / Print Preview Time Events report
- Time Display Increment of 1 second or 1, 6, 15 30 minute.
- Export time records to other programs
- Ability to select which columns are displayed on the screen, printed
and exported
- Hourly Rate settable per record
- Easy method to Add Time Information manually
- Create folders to help organize your work.
- And much more...
