ShareDraw 2.02
ShareDraw 2.02
Download: http://archive.info-mac.org/gst/grf/share-draw-202.hqx
ShareDraw is a full feature drawing application for the MacOS distributed
using the shareware system. It isn't crippled or limited in anyway - you
can try all its features without spending any money up front. All we ask is
that if you find it useful, please send in your registration.
ShareDraw Features:
ShareDraw has many more features than can be described in this short file.
A few features of special note are its multi-copy effects, powerful
gradients, graphics library support, color blends, text binding to any
curve, a very handy live help system, project management, 24-bit color,
rulers, grids, and PICT or EPS file export. Use the live help feature to see
how each menu and tool works.
The online help system (always enabled in unregistered copies) will explain
how all the tools and menus work. Review our electronic User Guide for
detailed instructions on how to use the more advanced features.
