Graphite 1.0.6 68k
Graphite 1.0.6 68k
Download: http://archive.info-mac.org/gst/grf/psh ... 06-68k.hqx
Graphite is a freehand graphite rubbing and texturizing tool for
applications which support Photoshop filter plugins.
With Graphite, you can select an arbitrary texture to use as your
"paper" texture. Once a texture is selected, you can apply pencil
strokes from 9H (very hard) to 9B (very soft and black) which interact
with the paper grain.
In addition, you can disable the pencil coloring and rub the texture
into the current image. If you have a pressure-sensitive tablet,
then you can rub lightly to get a little texture, or harder to push the
texture deeper into the image.
The README file indicated below is included in the distribution, and
includes a version history:
