iPod.iTunes 2.5
iPod.iTunes 2.5
Download: http://archive.info-mac.org/gst/snd/ipod-itunes-250.hqx
*** What does it do?
Unlike other iPod copy tools, iPod.iTunes provides real synchronization of
MP3/AAC/Audible tracks and even playlists entries from your iPod(s) to your
Mac(s).
iPod.iTunes saves your time because it automatically only copies those
tracks which are missing in the iTunes library, excluding duplicates. If you
wish, it provides also an option to show a list of tracks which are not in
iTunes and to copy only desired tracks from that list.
iPod.iTunes can be used to
- Keep music and playlists on different Macs up to date
- Do a full restore of tracks and playlists - i.e. after a hard disk failure
- Revert accident deletion of tracks and/or playlists, if these are still on
your iPod
- Clone an iPod
- Transfer an entire music library from one Mac to another via the iPod
Tracks and playlist entries can be synchronized together or separately. If
the tracks on the iPod already in the iTunes library and you only want the
playlists, you can use the playlist synchronization alone.
With every synchronization iPod.iTunes creates a date&time stamped iTunes
playlist containing the tracks which were copied. This gives the option to
easily add those tracks to existing playlists or to create new playlists
from the transferred tracks.
*** Requirements
Mac OS 10.1.2 - 10.3.2
iTunes 2.0.4 - 4.2
iPod firmware 1.0 - 2.1
*** Links
Homepage: http://www.crispSofties.com/
Readme: http://www.crispSofties.com/i.i/index.html
Download: http://www.crispsofties.com/i.i/ipod_itunes.dmg
