"Wunschzettel" for Newton
Download: http://archive.info-mac.org/nwt/app/wzettel-124.hqx
wzettel-124.hqx is the English version
wzettel-124-de.hqx is the German version
"Wunschzettel" is the German word for"list of wishes". Consequently
it is a (check-)list manager. I know, there are more list managers "out there".
But this one has a special feature: Each item you once made can be "remembered"
by "Wunschzettel". So after entering its name once you can reuse the item over
and over again just on two "taps".
A typical example is a shopping list. Instead of writing again and again items
like "bread", "tooth-paste", ... you can select these items from dynamically
growing popup lists. After a short time you have all those things in your popup
that you might want to buy. This is also quite usefull to check out if you have
forgotten anything to put on your list.
More Features of "Wunschzettel":
- Supports multiple lists (each one has its own pop-up lists).
- On each list, items can be assigned to one (of three) different named
categories.
- Sort selected items by four different criteria:
alpha, checked+alpha, categories+alpha, checked+categories+alpha.
