PrefsPatch 1.2 - Newton Pref/Formula Patch
Download: http://archive.info-mac.org/nwt/util/prefs-patch-12.hqx
PrefsPatch is a patch for the MessagePad which corrects an annoying user
interface "feature." Namely, that you have to tap twice to exit the
Prefs or Formulas rolls. When you install PrefsPatch, it replaces the
close box in these rolls with one that works PROPERLY, requiring only one
click to close the roll. You can still click on the overview button to
get back to the overview. PrefsPatch also places a dual-function button
on the notepad status bar for one tap access to the Formulas and Prefs
rolls. Freeware.
[ Tom Collins \ Innovative Computer Solutions / inLine | GNUT Top 10 ]
