The Atomic Mac 5.3.0
Download: http://archive.info-mac.org/sci/the-ato ... 53-ppc.hqx
The Atomic Mac is a periodic table of the elements for the Macintosh. In
addition to the usual information found in such programs, The Atomic Mac
also contains a wealth of nuclear information on each isotope, including
half life, decay mode, and daughter products. X-ray data (fluorescence and
binding energies) is also available. A molecular weight calculator makes it
easy to find the molecular weight of compounds. A shaded diagram showing
the ranges of physical properties makes it easy to visualize relationships
across the periodic table.
including half life, decay mode, and daughter products. X-ray data
(fluorescence and binding energies) is also available. A molecular weight
calculator makes it easy to find the molecular weight of compounds. A
shaded diagram showing the ranges of physical properties makes it easy to
visualize relationships across the periodic table. Photon interaction data,
both in tabular and graphical format is also available.
Data is displayed for the following physical properties:
Density
Heat of Vaporization
Heat of Fusion
Specific Heat
Thermal Conductivity
Linear Expansion Coefficient
Melting Point
Boiling Point
Atomic Radius
Covalent Radius
Magnetic Susceptability
Electrical Resistivity
Electron Affinity
Electric Dipole Polarizability
State (gas, liquid, solid)
Photoelectric Work Function
Electronegativity
Crystal Structure
Abundance in Earth's Crust
Abundance in Earth's Sea
Abundance in Earth's Atmosphere
Abundance in Solar System
Photon Interactions
Visible Light Spectra
Magnetic Dipole Moment
Electric Quadrupole Moment
