SimpleText Color Menu 3.4 - greatly enhances SimpleText
Download: http://archive.info-mac.org/text/simple ... enu-34.hqx
Program: SimpleText Color Menu Installer 3.4
Author: Alessandro Levi Montalcini
Price: $10 (shareware)
Register: http://order.kagi.com/?67
Download: http://www.montalcini.com
SimpleText Color Menu is a drag & drop utility that
installs an extra cool Color menu and an extra useful
Goodies menu inside Apple's SimpleText text editor
(all versions from 1.1 to 1.4 are supported).
New in 3.4:
- A new option allows you to remove all duplicate lines when
sorting the selected text.
- Fixed an incompatibility that prevented the Options and
Windows submenus from showing up on some systems.
Previous features include:
- A Color menu.
- A Windows menu.
- Default style settings.
- Faster Find and Replace commands.
- Document statistics.
- Custom print margins, don't print page numbers.
- Open Internet URLs through Internet Config.
- Open the current document with an external viewer.
- Use extended editing keys to do keyboard selections,
word-by-word cursor movement, forward delete, etc.
- Choose any non-standard font size.
- Automatically open large documents with a word processor.
- Optionally open read-only documents as editable text.
- Smart quotes.
- Line sorting.
