Back-Drop for Decor - A better drag-n-drop desktop picture util
Download: http://archive.info-mac.org/gui/back-drop-for-decor.hqx
Back-Drop for Decor complements Francois Pottier's shareware utility
Decor by allowing you to choose a desktop image on the fly. You can drag
an image onto it to display that image, or drag a folder onto it to have
Decor choose from the images inside according to its preferences. Plus,
there's an Undo function: if you pick a picture that pickles your pucker,
you can Undo the picking of the last picture you picked! It's great for
trying out images on your desktop, for example. Just drag each one onto
Back-Drop's icon until you find one you like. If you don't like it, click
Undo and go back to what you had.
Thoroughly-commented source is included for the sake of other budding
AppleScripters.
System Requirements
* Francois Pottier's $10 Shareware utility Decor
* You need Applescript installed, since this is really just an
Applescript application.
See the Read Me for more information. Also, check it out on the web:
http://neddie.simplenet.com/software.html
John Burwell
