FinderKeeper 1.5 (_User_Interface)
Download: http://archive.info-mac.org/gui/finder-keeper.hqx
FinderKeeper version 1.5 from Elsware Ltd.
WHAT IT DOES:
FinderKeeper organizes your desktop by neatly stacking windows
on-the-fly. Each disk on your Mac is given a starting point, and as
you open windows they cascade down and to the right. The result is a
neat, logically arranged desktop - all done automatically.
BENEFITS OF USE:
FinderKeeper shows you not only what files are on your Mac, but also
where they are stored. At a glance you see that ³Letters to Mom² is
inside of ³Personal Documents² which is on ³Macintosh HD². A smartly
arranged desktop encourages better organization which in turn
increases efficiency!
NEW V1.5 FEATURES:
* Now works on PowerPC and 680x0 systems (FAT).
* New control panel sets custom window offsets.
* Fully compatible with Microsoft products.
* Tested on systems as old as 7.1.0.
* Better support for AppleScript recording.
SYSTEM REQUIREMENTS:
A Macintosh compatible running system software 7.1.0 or later.
The new FinderKeeper v1.5 keeps your Mac desktop in order!
http://www.elsware.com/finderkeeper.html
