MacRun 1.5 (mrun15.hqx)
Download: http://archive.info-mac.org/gui/macrun-15.hqx
MacRun 1.5 adds many new features to the Windoze-like "Run..." command for
the MacOS!
- MacRun 1.5 adds the much-requested "Type-Ahead Feature". MacRun will now
offer suggestions based on applications/documents/URLs that it has opened
before.
- MacRun 1.5 will allow you to simply type the name of any
application/document that is part of the History, Application or Document
lists.
- MacRun 1.5 will allow you to set "pre-defined" applications and documents
which you can launch with the click of the mouse (similar to several
launcher programs available).
- MacRun 1.5's interface is much more customizable.
- Totally revamped preferences window for better organization and to make it
easier to use with all the new options.
Scott Crick
SearchWare Solutions
http://www.radiks.net/~search
