[*] - CEPT Modem Tool 1.1
Download: http://archive.info-mac.org/comm/ctb/ce ... ool-11.hqx
Organization: STALKER GmbH
CEPT Modem Tool 1.1
The CEPT Modem Tool is a Connection Tool for Communications Toolbox.
It lets you establish a connection with a remote computer through a
modem attached to your Macintosh (or through shared network modems).
It supports low-level CEPT-1 protocol used in European Videotex
systems. It uses CCL script files (the same files as ARA uses) for
controlling the modem, thus the user interface is as clear and
simple as it is in the Apple's Remote Access Setup control panel.
The tool can also trace CCL scripts. Balloon Help(tm) supported.
The CEPT Modem Tool can be freely distributed on non-commercial basis.
If you want to bundle the CEPT Modem Tool with your products, contact:
Stalker Software GmbH
Fax: 49(221) 442 138 (Cologne)
7(095) 938 2136 (Moscow)
Internet: [email protected]
