MIME-Version: 1.0
--Info-Mac-Digest
Info-Mac Digest Mon, 17 Nov 97 Volume 15 : Issue 250
(A) 68LC040 in an SE/30?
(A) Daystar 100MHz PPC card and OS 7.6
(A) Java compiler wanted
(A) System Error 1708?
(A) virtualPC
(Q) Data mining application
(Q) Floppy drive problem
6200 Monitor
8500 Stock 2GB HD
[A] System Error 1708?
[A] Viewing & Scaling PS Graphics in Word 5.1a
[A]: Java compiler wanted
a request
AOL 3.01 help
CD-R Drives and Software
Cheated by Microsoft
Default font substitutions
Demise of MATLAB for the Macintosh
descriptive abstracts
email forward >>>
Info-Mac Digest V15 #246
Internet Dialer clears browser home page
Long File Names in Virtual PC
Musical composition software?
My Mac won't stay off!
newton-mac communication issues (A)
Picture cataloguer program (Q)
Powermac 7500 StartUp problems
Saving Images
SnapScan
Thermal Recalibration and AV Drives
Translating AppleWorks file
Unimplemented Trap
Upgrading from 7.5.3-->7.6
containing gigabytes of freely distributable Macintosh software. For more
information, visit the Info-Mac Web site at .
Email Addresses and Instructions:
the Subject line.
the Subject line.
form at before contacting us.
FTP and Web Addresses and Instructions:
* To submit files larger than 800K, email a description to
binhexed file to info-mac.org, using the userid "macgifts and the
* A full list of Info-Mac mirror sites is available at the URL below:
* Search the archive at .
Info-Mac volunteers include Gordon Watts, Adam C. Engst, Demitri Muna, Mike
O'Bryan, Michael Bean, and Liam Breck.
the main Info-Mac machine.
--Info-Mac-Digest
Content-Disposition: attachment; filename="Info-Mac Digest V15 #250"
Date: Fri, 14 Nov 97 11:54:42 -0000
Subject: (A) 68LC040 in an SE/30?
>I have an old SE/30 lying around as well as a 68LC040 chip that I took out
>of a PowerBook 540. Can I make the SE/30 an SE/40 using this old processor?
No. The CPU daughtercard from the PowerBook 500 series is a proprietary
module which holds the CPU, ROM and a large ASIC which I believe is
implicated in address decoding and peripheral interfacing. It is
absolutely proprietary to the PB500 and since the CPU is in an MQUAD
pack, you can't even remove the chip to use elsewhere. If you want to
find a use for that card, you may be able to sell it to a PB520 user
anxious for a little more speed. You can also overclock the card to
40/80MHz, fwiw.
I believe Daystar made a 68lc040 accelerator for the SE/30 but it will be
hard to come by these days.
The SE/30 in this day and age is probably best employed as a file or web
server unless you have a specific application in mind which will fit a
512x384 1-bit display. You can stack the machine up with positively
hordes of 30-pin RAM, put a PDS Ethernet card in it, tuck it under your
desk and provided you don't kick out the power cable, it will keep
chugging along for years.
-- Lewin A.R.W. Edwards (Certified Apple Engineer)
Home:
Resume:
Date: Fri, 14 Nov 97 11:54:45 -0000
Subject: (A) Daystar 100MHz PPC card and OS 7.6
>Like an idiot, I put the OS 7.6 upgrade on my son's 2si, that I had updated
>with a daystar card on 7.55 a year or so before. Now I can't boot the card, I
>can't deinstall the OS and reinstall 7.55 and I'm thoroughly disgusted.
This configuration, as you've discovered (g) is not supported. Recovery
is simple and should not cause loss of data. There are a couple of routes
you could go down, and this is not the simplest, but it is the most
certain (assuming you have System 7.5, if you don't, then I'm not sure
how you got into this situation in the first place):
* Remove or disable the accelerator.
* Boot off 7.5 Install Me First.
* Install System 7.5 "for any Macintosh".
* Reinstall the accelerator and any required extensions.
* Upgrade to 7.5.3 then 7.5.5.
>I'll certainly think twice before I try OS 8 on my NuPowr upgraded PB 500!
>(which does run with 7.61)
The NuPowr cards for PB500 series use the same ROMs as the Apple PowerPC
upgrade and to all intents and purposes they are identical to the Apple
card. OS8 will work very well indeed on a PPC-upgraded 500 series,
whether it is the Apple card or a NuPowr. However, you will not be able
to boot directly off the OS8.0 CD-ROM on a PPC-upgraded PowerBook 500
series machine (leastways, I have never managed it on units with the
Apple card). You will need to boot off the hard drive.
Home:
Resume:
Date: Fri, 14 Nov 97 11:54:47 -0000
Subject: (A) Java compiler wanted
>I'm looking for a Java compiler, hopefully shareware. Does any one have any
>suggestions?
The JDK for MacOS from Sun, now no longer supported it seems, should
still be available from , and it is free. At
the last I checked, it appeared that Sun is no longer developing the Mac
JDK; they seem to have passed the reins to Apple. Unfortunately as you've
probably noticed, the MRJ SDK does not include a compiler.
I'm not sure how large the Sun JDK is (I don't have it installed right
now), but I might be able to email it to you if you can't find it.
There are several commercial options, of which I have tried CodeWarrior's
Java support (Metrowerks also sell, or used to sell, a special cut-down
version of CodeWarrior, "Discover Java Programming on the Macintosh",
which had ONLY the CW IDE and the Java compiler), Symantec Cafe, and
Symantec Visual Cafe.
If you are developing something that's mostly user interface with not
much meat behind it, then Visual Cafe is worth a look. If you are
developing something which has lots of complex code behind the scenes,
and not much user interface, then Cafe (which is the only one of those
tools above I actually use on a regular basis) is worth a look. I find it
irksome to develop complex algorithms in visual languages, and equally
irksome to develop complex user interfaces in traditional editor-compiler
IDEs.
Home:
Resume:
Date: Fri, 14 Nov 97 11:54:50 -0000
Subject: (A) System Error 1708?
>Can someone please explain "System Error -1708"?
>It doesn't seem to do anything and flashes an alert sometimes when I open
>something like Claris Works after having opened something like Thorsten
>Lemke's Graphics Converter, but not always. Of course not. NUM's Disk
>Doctor doesn't find anything, either.
This appears to be a problem in GraphicConverter, though exactly what it
is, I can't say. If you switch configurations with Location Manager while
GraphicConverter is open, you will *always* get this message, but it
appears to be completely harmless. It's not actually a MacOS error - it's
an error dialog in GraphicConverter itself.
Home:
Resume:
Date: Fri, 14 Nov 97 11:54:52 -0000
Subject: (A) virtualPC
>I can't install win95 with VirtualPc because my computer can't read the
>cdrom.
>I have Virtual PC 1.07b so how can i do to install win95 cdrom???
1.07b? AFAIK the latest version of Virtual PC is 1.0.1. If you have the
DOS version of VPC, you need to install the integration utilities which
come with VPC so DOS can access your CD-ROM drive. This will create a
directory in your virtual C drive, default name C:\CNTX, which contains,
among other things, CDROM.SYS. It will also add a line like this to your
CONFIG.SYS:
device=c:\cntx\cdrom.sys /d:idecd001
and a line like this to your AUTOEXEC.BAT:
mscdex /d:idecd001
Once you have installed Win95, you should go to
and download the latest version of the Win95
integration drivers, which will significantly improve mouse smoothness
and video speed. It's quite a large download.
Home:
Resume:
Date: Sun, 16 Nov 1997 14:44:00 -0800
Subject: (Q) Data mining application
I seem to remember seeing a submission to the Info Mac Digest about an
application that does "data mining". In other words, the application
applies artificial intelligence algorithms to data to extract new concepts,
etc. Does anyone remember the name of that application?
Thanks!
Mark Allen
Date: Wed, 12 Nov 1997 17:09:40 -0800
Subject: (Q) Floppy drive problem
I have the strangest problem with my floppy drive. I have a Power Mac 7500
running OS 8.0. Sometimes the floppy drive reads an inserted disk just fine
and sometimes, when the same disk is inserted, the system says the disk is
unreadable or the diskette icon does not appear on the desktop or the
system freezes after the icon appears. For one application I received four
800 K disks to do the installation. All but one of these disks are read
fine each time they are inserted into the floppy drive. The one disk
freezes the system upon insertion 3 times out of 4 (note: but not always).
On the other hand, this same disk can be read fine in another Mac.
The Apple tech replaced the floppy drive with an Apple replacement unit and
also the floppy drive ribbon cable. The problems persist. He ran logic
board diagnostics and no problems showed up.
In the absence of knowing specifically why the problems I've described
could occur, he feels that I should replace my mother board because the
only thing he couldn't replace was the floppy disk controller. This is
quite costly!!!
Has anyone encountered similar problems? Were the causes of the problems
ever clearly isolated? If I really need to use the floppy drive, is my only
course of action to replace, in effect, the whole computer because the
flakiness of the floppy drive cannot be directly repaired?
Thanks for all inputs!
Mark Allen
Date: Fri, 14 Nov 1997 10:01:29 -0500
Subject: 6200 Monitor
>> a lime green haze feels the screen. Sometimes during
>>a very frustrated moment I'll smack the sides of it and it shakes into place
>>but this is few and far in between. Leaving the monitor on doesn't help.
>I had the same problem with my 6200 monitor and after trying everything in
>the troubleshooting guides Apple replaced it at defective. Give their 800#
>a call... it was a very easy process and I suspect not the first time they
>had done it...
>Don
Yes, this is a well-documented problem with the Apple Multiple scan 15"
display. It loses the red gun. I would suggest calling Apple Customer
Relations with this issue at: 1-800-776-2333 (or 1-800-233-6555) They
should rectify the problem for you - in or out of warranty!
Donna
PS - I am sitting here looking at the same green/blue hazed monitor -
awaiting refurbished replacement (which is on back order)
Date: Thu, 13 Nov 97 22:09:48 -0600
Subject: 8500 Stock 2GB HD
Does someone know the specifics of the 2GB hard drive that Apple included
with the 8500s (i.e. make, model, manuf., etc.)?
Jason
[email protected]
Date: Fri, 14 Nov 1997 08:30:24 -0600
Subject: [A] System Error 1708?
from MacErrors 2.0.1:
>-1708 - errAEEventNotHandled
>AppleEvent Manager - the AppleEvent was not handled by any handler
from Danny Goodman's The Complete AppleScript Handbook
>-1708 - Reference doesn't understand the commandName message.
AppleEvent's are high level messages used by AE-aware programs to
communicate with each other and the system. AppleScript for example is a
scripting interface for sending AppleEvents.
i'm not a programmer, but perhaps you have a background app / macro
running? an applescript app maybe? you might check your startup items
folder.
it would seem that _something_ is sending an AppleEvent "commandName" to
"reference" (target app). apparently, the target app is being located and
_something_ is sending a message to it, but the target app doesn't
understand, causing the AE Manager to generate the error.
or it could be that either of your programs are causing an error somehow or
not finding the resources they need... i use CW4 alot and never get that
particular error, but i do get it when testing / debugging an AppleScript
occasionally.
make sure that applescript and associated files are installed properly.
good luck with it
george s stripling jr
Date: Fri, 14 Nov 1997 15:05:17 +0100
Subject: [A] Viewing & Scaling PS Graphics in Word 5.1a
>I receive regular graphics by e-mail from a
>collaborator in Canada in the form of Post-Script
>files. These ultimately need to be pasted into
>MSW 5.1a scientific documents - and in the
>process they usually need to be reduced in size
>by anything from 80% to 50% or less. To do this I
>have been saving the original Eudora docs. as
>Word files, applying the PS style, printing the
>graphic, scanning the graphic with Ofoto, pasting
>the Ofoto graphic into my Word scientific
>document and and finally (whew!) scaling as
>required within Word. Surely there must be an
>easier way to produce the same effect? All
>suggestions will be very gratefully received.
>TIA -
>Fergus Lalor
Word 5.1a can import (and scale) Encapsulated Postscript
Files (eps).
There is a utility PS2EPS+ in the archives
(/info-mac/gst/grf/ps-to-eps-plus-10.hqx) that is
supposed to be able to convert single-page postcript
files into .eps files (I haven't tried it).
If this does not work, you should ask your correspondent
to mail you .eps files instead of .ps files
Hope this helps
Minus van Baalen
Date: Thu, 13 Nov 1997 17:14:45 -0800
Subject: [A]: Java compiler wanted
MRJ 1.5 from Apple is available. The full down load includes a development
environment.
MRJ 1.5 (Mac OS Runtime for Java) is now available from Apple.
CodeWarrior's "Discover Programming" set includes a full Java development
environment $79. Metrowerks at 1-800-377-5416
You might also check out the following:
This tidbit is from:
Rob Wittner,
>From JavaWorld:
"In our annual look at Mac-based IDEs, we dig into four integrated
development tools and weigh the pros and cons of the Mac as a Java
development platform. If you're a Mac user who wants to use your favorite
platform for Java development, you won't want to miss the results of our
rigorous testing and benchmarking."
________________
0-0
(_)+
Date: Sun, 16 Nov 1997 19:55:23 -0500
Subject: a request
Dear Digest readers,
I have yet to see a Kaleidescope pattern that looks like the Rhapsody
Developers release. Has anyone made one?
Where can it be downloaded? Thank you.
Sincerely,
[email protected]
http://www.ameritel.net/lusers/abrody
Date: Sun, 16 Nov 1997 20:37:21 -0500
Subject: AOL 3.01 help
Hi all,
A colleague has run into a slight problem upon upgrading from AOL 2.7 to
3.0. With 2.7, he could use the browser just fine, since it used the AOL
client to get through to the Net. With AOL 3.0, however, they switched it
so that you need to be using AOL Link in order to get the brower to access
anything. Since the upgrade, however, he hasn't gotten it to work. I tried
to do it unsuccessfully. I trashed MacTCP (and Prep), TCPack for AOL, AOL
Link, the AOL 3.0 folder & reinstalled them from the AOL 3.01 installer. I
started AOL & selected prefs under the member menu. I clicked on AOL Link &
made sure that the checkbox was on to always use AOL Link, & clicked the
configure button, which is *supposed* to do everything necessary to
activate AOL Link. I rebooted & made sure that AOL Link was the selected
option in MacTCP. When I clicked on more=8A, I saw that all DNS info was
blank, it was set to get address from server & I forget the subnet mask
part, but it was pretty plain vanilla (didn't seemed configged for
anything). Personally, I've always used AOL in the other direction (bring
your own access, i.e. access it via a TCP connection to my ISP). I was
hoping that the AOL link actually made MacTCP bypass its normal stuff &
force it to "ask" AOL's client for all info it needs. I tried using a known
IP address, to be sure that it wasn't the missing DNS info. Can anyone who
uses AOL to access the Net let me know how AOL configured their MacTCP?
The stats are:
Mac PPC 5200, plenty of RAM, but VM turned on (wife does graphics work I
think), AOL for PPC 3.01, MacTCP 2.0.6, MacOS 7.5.3 (I know, he should
upgrade to 7.5.5)
Any help is greatly appreciated.
Mike
Bikers don't *DO* taglines.
Date: Thu, 13 Nov 97 22:09:34 -0600
Subject: CD-R Drives and Software
Would anybody recommend any particular CD-R drive for recording CDs?
Also, what software is the best (what software is available)?
Jason
[email protected]
Date: Fri, 14 Nov 97 09:10:39 -0400
Subject: Cheated by Microsoft
Sent: 11/14/97 8:54 AM
To: [email protected]
2 month ago i received a notice in the mail saying that as a regitered
user of Microsoft
Encarta 97 Deluxe Encyclopedia, i was entitle to the 98 version for about
45$ Canadian.
They also claimed that the product was almost ready to ship.
So i send in my money and for about a month, expected almost avery day,
the product to arrive at my door. No way....I had 3 weeks ago to contact
theyre on line support; What a nightmare!
First phone call on nov.3 took me over 20 minutes to complete, since i
was bounce from
one operator to the next, saying that my order was delayed because they
could,nt read
the amount on my Post Canada Mail Order, and that they had never
encountered a situation
like that before. Just give us 3 days they said and it shoud be settle.
A week and a half later nothing! So i decided to call them back, and,
this time it took me 30 minutes of on hold/boumce to different operator
to find out that my order was delayed because, as opose to what they had
claimed before, this time they admited that the Encarta 98
product (for Mac) was back order because of a bug.
I kindly aske for my money back saying that i had enough of this run
around.
They said ok, but told me that it would take them anywhere from 4 to 6
weeks to do so.
What a drag.
Questions:
1) Y does Microsoft feel that they need to lie to customers
2) Y is theyre on line service sucks so mutch
3) Y is Microsoft feel the need to send to registered users
mail to sell them a product that is not even ready
4) Is Bill Gates financing the purchase of his stock in Apple
selling air
5) Y do i even bother considering Microsoft product to purchase in the
future
6) Y does it take Microsoft 4 to 6 weeks to reimburse me
7) Y is it that after Microsoft promisse that in the future, window and
Mac products
would be release at the same time when they can't even get Encarta
ship on time to
Mac users
Pledge
1) I will never lose another minute on line with incompetent Micro-Cerfs
2) I will never by a other Microsoft product as long as i live
3) I will make shure that everyone knows about it
4) I will not stop complainning about it to the APA until i get what they
howe me
5) I will buy all my up grades in store now and never again mail order
Thank you,
Hugo Trottier
The Dr
[email protected]
Date: Thu, 13 Nov 1997 17:37:37 -0600 (CST)
Subject: Daystar 100MHz PPC card and OS 7.6
At 9:52 AM -0500 11/11/97, [email protected] wrote:
>Help?
Here's what I'd do.
Remove the Daystar card. The system may boot now. If not, boot with an
old [7.0? 7.1?] Disk Tools floppy; maybe the one that came with the IIsi,
if you still have it. This will allow you to delete the existing System
Folder.
You can then install a new copy of 7.5.5 and replcae the DayStar card and
software.
chazl - 11.13.1997 - [email protected]
Date: Thu, 13 Nov 1997 22:27:02 -0600 (CST)
>updated
>card, I
>500!
>Daystar no longer supports the product.
Well, I'm running a IIci with a daystar PPC upgrade and 7.6 upgraded to
7.6.1, and It works perfectly. Aside from a few minor things (I can't run
MkLinux on an upgrade card. wahhhhh) I have had few problems.
I can pull the card out and boot back to the 25MHz 68030 on board, so
maybe you can try the same thing? If you can boot the old processor, then
deinstall, go for it.
I can also swap between card and motherboard with the control panel, but
you can't since you can't boot. Ooops.
Is it doing the sad mac, or giving an error, or what?
Personally, I want to test run os8 on my machine before I purchase it,
since no one around here accepts a package after you return it. Sad part:
I don't know that it's legal. Is it?
-= Derek Jacobs =-= [email protected] =-
"Why me?" "Why not?"
Date: Fri, 14 Nov 97 08:15:20 PST
On Tue, 11 Nov 1997 09:52:33 -0500 (EST)
> Help?
> Charlie Watson
> a very amateur MAC enthusiast
I have a IIci with the Daystar Turbo 040, and the official
instructions from Apple (someplace in the 7.6.1 readme files) stated
that 7.6.1 supported this configuration whereas 7.6 had not. The way
to get from 7.5.x to 7.6.1 was to:
1. remove the accelerator card (now you have a supported 68030 with 24
bit clean ROM),
2. update to 7.6
3. immediately update to 7.6.1
4. reinstall the accelerator card.
An Apple caveat was DO NOT turn on virtual memory.
I have been rock stable on 7.6.1 since it became available. It has
been far better than 7.5.x, though 7.5.5 was pretty solid too.
So, does anyone in this knowledgeable community know whether the same
procedure will work for Charlie with his Daystar 100MHz PPC card?
As I read this over, it occurs to me that this should not work without
some further magic. I'm guessing that the resulting system was tailored
by the 7.6 and 7.6.1 installer scripts for a 68030 based machine. It
was good enough for the 68040 accelerated system, which is at least
the same processor family
would be good enough for a Power PC (601/100?) based system
Personally, I'm guessing that the resulting system will need more
tweaks.
Peter
[email protected] or [email protected]
Date: Fri, 14 Nov 97 08:56:11 GMT
Subject: Default font substitutions
Is there a way under System 7.1 to sepcify what font substitutions on the
screen should be made when an application tries to use a font that is not
installed on the system? E.g. a certain game tries to use the New York font,
and if it is not installed, Chicago (I think) is used instead. Sadly,
Chicago doesn't look a great deal like New York. I would like to specify
that Times, or Georgia should be used instead, whenever New York is
requested by an application. (BTW Georgia, available free from the Microsoft
Typography web site, is rather good at small sizes on the screen.)
Thanks in advance.
Ian.
Date: Thu, 13 Nov 1997 14:23:26 -0700
Subject: Demise of MATLAB for the Macintosh
>From The MathWorks:
The MathWorks has made a decision to stop development on the Macintosh
platform after we release MATLAB version 5.2, which we expect to ship
in the first quarter of 1998. It's a difficult decision for us, one we
arrived at only after a lengthy and thorough analysis of recent trends.
We know this will come as a great disappointment to some MATLAB users
and we will do our best to minimize the impact.
We are doing this because our Mac installations have declined steadily
in the past few years in both our industry and educational sectors
(even while MATLAB installations overall have shown robust growth) to
a point that it is no longer justifiable to support the platform.
We regret the disruption our decision may cause some of you, but we
feel it is the best way to focus our development efforts looking
forward. We are fortunate to have skilled engineers on our Mac team
and that their talents will go toward enhancing our products in new
ways that will benefit the entire MATLAB community.
What This Means to MATLAB Users on the Mac:
1) We'll continue to provide technical support to Mac users.
2) You'll receive MATLAB 5.2 automatically if your current MATLAB
version and associated toolboxes are at release 5.0 or 5.1
3) MATLAB 5.2 on the Mac will be an industrial-strength release and
provide an up-to-date solution on the Mac well into the next year.
4) We will continue to offer 5.2 for the Mac as long as there is
sufficient demand for it.
5) You may transfer your Macintosh product(s) to PC Windows FREE of
charge if your product(s) is at the current version.
6) Full credit towards the purchase of a workstation license. If your
Macintosh product(s) is at the current version, you can use the
Macintosh current price as a down payment on a Workstation and
receive 12 months of maintenance.
NOTE: This product transfer policy for the Macintosh will be valid
until 11/1/98
If you are interested in transferring your license to a different
platform, please contact Customer Service directly at 508-647-7000
ext. 3 or just reply to this email.
Sincerely,
The MathWorks
Date: Sun, 16 Nov 1997 14:54:59 +0100
Subject: descriptive abstracts
I'd like to encourage all thosw uploading some software for the info-mac
archive to say WHAT the software does. Texts like those
> Hello, here is the latest version of xxxxxxx. It should replace any
> previous versions of xxxxxxx you might have in your archives! The current
> version is x.x.x
> To see what's new, please read the "Read-Me" file!
> All updates and info will be posted to my WWW site first at:
Reading this, I have no possibility to judge whether the product could
be interesting for me - just beacuse I do not know what it does. And
since I am nut downloading every single upload (I don't have unlimited
time to read through readme files, and I don't have unlimited funds to
pay for long telephone calls for downloads), your software won't be seen
by me or by other potentially interested users.
Best wishes, Christian.
Christian F. Buser - phone (+41-56) 426 64 86
Obere Kirchzelg 12, CH-5430 Wettingen (Switzerland)
Look at
Date: Fri, 14 Nov 1997 11:05:44 -0500
Subject: email forward >>>
How can you get rid of the ">" that appears in front of lines when you
receive email that has been forwarded i.e. > -Lily Tomlin
TIA
[email protected]
Date: Fri, 14 Nov 1997 02:35:10 -0500
Subject: Info-Mac Digest V15 #246
In article , [email protected] wrote:
> Date: Tue, 11 Nov 97 23:12:57 -0000
> From: "Lewin A.R.W. Edwards"
> Subject: (A) System 7.6.1 Error type 10?
> >Quick question... Under system 7.6.1, what exactly is an Error type 10? I
> >looked it up with "Easy Errors" 1.2 which indicates the description as
> >"line 1111 trap error", but that really does not help me out a whole lot.
> extensions in use, or the OS itself. However I never had nor heard of
> such a problem with 7.6.x, so it's probably a third-party problem.
Motorola StarMaxes give this error constantly. After checking with
Motorola, they said I should avoid using programs that gave the error
message. I've done some investigatin' of my own, and part of the reason
seems to lie in buggy ATA driver on the ROM (which makes Apple's fault).
All StarMax owners should immediately upgrade the ATA disk driver using
the latest Drive Setup 1.3.1. FWB is currently looking into the problem.
Date: Sun, 16 Nov 1997 20:57:42 -0800
According to the 1995 doc I got offline, that would be:
-1708 errAEEventNotHandled Event wasn't handled by an Apple event
handler
~~ Tony
SSS MIDI Rock Mac
Date: Sat, 15 Nov 1997 12:03:00 -0800
Subject: Internet Dialer clears browser home page
I recently upgraded from a PB-170 running System 7.0.1 and MacTCP/MacPPP to
a PB-3400 running OS8 with a short transition through OS 7.6. All seems to
work fine, although it took quite a while to figure out how to really use
OT for multiple configurations. I still have one anoying problem. I have
several different setups I use daily and have each defined. However, when
switching between them using Internet Dialer, the Internet Config field for
the browser home page gets cleared. Since I use a local page, I would like
it to always be the same, but it would not be unacceptable to set it once
for each TCP/PPP configuration - if I could figure out how to do it. I
would appreciate any suggestions as resetting it each time I switch (3-4
times per day) is painful. Thanks,
-- Doug
Date: Thu, 13 Nov 97 10:48:25 -0500
Subject: Java compiler wanted
>suggestions?
Check out Apple's Macintosh Runtime for Java (MRJ) developer's kit. I
think the latest public version (1.5.1) has an SDK available that
includes the standard javac compiler. You can then write code in BBEdit
or even SimpleText and then compile it with javac and MRJ. Best of all,
it's free!
If you need access to the latest MRJ, I suggest joining the MRJ
Developers list. You also might want to poke around Apple's Java page
for some pointers to internal Apple and
external Java resources.
Hope this helps,
Chris
Date: Sun, 16 Nov 97 09:18:07 +0000
Subject: Long File Names in Virtual PC
I am using VPC, it has been updated to 1.0.1 and need to find out if
there is any way to keep the long filenames when accessing WIN95
computers over a network. It seems the whole naming scheme defaults to
8.3. Are there workarounds? I have no trouble using VPC to access the
Network, just this #)($*)SD(* naming problem..
TIA
Rick
Date: Sat, 15 Nov 97 12:23:03 +0000
TIA
Rick
Date: Thu, 13 Nov 1997 23:18:28 -0500 (EST)
Subject: Musical composition software?
{Do not reply to the address from which I'm posting, oh helpful Mac-faithful,
that address doesn't accept email. It's an anti-spam thing. See signature
for correct address}
I'm visiting my folks' house and my Mom wanted to be able to write down the
notes that constitute the musical score that her choir wants to learn to
sing, then transpose it according to the vocal needs and ranges of the
singers. I told her she should do this on the Mac and sat down to the task
of re-familiarizing myself with the interface. I have Musicshop and the
shareware program MIDIgraphy on my Mac and figured between the two of them
would be an adequate solution. You know...new document, grab note value
(half, eighth, quarter, whatever), click on the proper position on the staff
to put that value there, go to the next note, etc., relying on the software
to count note values and put in the bar lines, simple stuff, right?
Well, MIDIgraphy doesn't have a classical music-staff interface for creating
new documents; and Musicshop, although it does, has a truly horrible
interface for the project (obviously their mind was on how to assign voices
to each track and how to speak to various different MIDI devices); I found to
my annoyance that although there were three different places in the overhead
toolbar from which I could choose a note value, the note actually created
would invariably be an eighth note no matter what I did. Wonderful.
(Version 1.0.2 in case you're wondering. I'm not feeling inspired to
upgrade).
No problem, I thought. I logged on, poked around a bit, and downloaded
Player Pro, Anthem, and a demo of Nightingale. All say they do musical
notation. Nightingale, I quickly learned, is designed so that you can't
print what you produce unless you are a registered user, and apparently the
part I'd downloaded wasn't complete in and of itself, so I put it off for
later. Anthem also landed incomplete, informing me that I needed the MIDI
Manager or the OMS thingie from Opcode, plus the Adobe Sonata font, just to
run it. Onward to Player Pro.
Cool, it gives me a classical interface. Cool, it deposits the desired note
value in the spot where I click! Uh oh, way uncool, it changes the note
value of notes I've already put down depending on the horizontal location of
where I click to put the next note!?? Hmm, gots little numbers along the
top. I practice clicking at the intervals most likely to agree with the
values I've already assigned the previous notes. Manage to put three
consecutive quarter notes in a 4/4 measure but can't get a fourth quarter
note in to save my life. No matter where I click the third quarter note
becomes something horrible like an eighth tied to a sixteenth followed by a
spattering of tied notes that cascade across into the next measure. Nasty.
Ditch Player Pro.
Go to Opcode site, grab the OMS thingie, picking the Lite version cuz I'm not
trying to control a MIDI device, QuickTime Musical Instruments will do fine.
Install, restart, launch Anthem, get messages that I shoud've grabbed the
full sized OMS package, more nasty messages about Sonata font, and finally
I'm in Anthem. No staff in sight, I guess they weren't kidding about the
Sonata font (Musicshop says that too but in Musicshop I did at least get a
staff and bitmapped versions of notes for my screen). Go to Adobe's site.
Looks like I gotta buy a CD-ROM from them to get the damn Sonata font.
Go back to MIDIgraphy, using the graphical interface, click to create notes
and drag to pitch positions (I like this interface), make a melody line.
Save doc. Open Musicshop, import the MIDI file. First measure is OK, with
4 quarter notes. Second measure begins with the assumption that I started
off with a sixteenth rest. Everything that follows is abominably syncopated,
impossible to sightread.
How the bloody hell do I find a no-bells and no-whistles music annotation
program? All I want to be able to do is click on the damn staff and say "You
are a quarter note. You are a C" and go to the next note, etc., until I have
a composition in place, and be able to save as a MIDI file. It doesn't have
to know from Yamahas and Casios, wave forms, timing synchronization
protocols, or digital sampling. It need not play with MODs, AIFFs, or
tinkertoys. Would be nice if it could import or open existing MIDI files.
Would be nice if it could print. Would be nice if it were free. Would be
nice if it were reasonably priced shareware if not free.
Allan Hunter
{remove the spaces, it's an anti-spam thing}
Date: Sun, 16 Nov 97 19:40:00 +0000
Subject: My Mac won't stay off!
I have a Mac 7200/90 OS8 and everytime I turn it off, after a few seconds
it turns back on. I've reinstalled Sys OS, the Energy control panel,
thrown out the energy prefs., rebuilt the Desktop, zapped the PRAM, the
only thing that works is if I unplug it! This is not a problem during the
week but usually I shut down over the weekend. Additionally, none of the
energy saving features work. I am open to your ideas.....
TIA
Rick
Date: Thu, 13 Nov 1997 18:31:38 -0600 (CST)
Subject: newton-mac communication issues (A)
I hope the following remarks will help this list see the
importance of communications issues to both mac and newton owners. For
example, I wish to market my newton aps to mac owners who might think of
buying a newton, but not think of it were they not to see discussion here.
Just because apple spun off newton doesn't mean Steve doesn't think the
mp2100 is dynomite. And how come the only stockholders in newton are apple
employees. I'd say newton discussion is relevant here and with to show it
below.
Dr. Adam O. Horvath, Faculty of Education and Department of Psychology
wrote : 1 I have tried to synchronise my PIM (Claris Organiser v2.0) on
my desk top macine with the Newton using Apple's new Newton Connection
Utilities...
I write :
Does this Newton Connection Utilities contain "works". I've done a
bit of export of newton works notes I quietly take in physics colloquia
(don't dare use a keyboard). Works sounds like claris works and allows
import to and export from various xtnd translated mac files.
Adam continues :
2 The Newton has a IR communication device built into it: What can it
communicate with?!
I write :
As far as I knew another newton. Steve Weyer wrote a seminal work
on endpoints which make a user layer which hides what it is finally
communicating through, serial, ir, or internet. I wish that I get the
nerve someday to make a two newton game! It would keep these two little
girls from fighting over one newton and make them play with each other.
He goes on :
Not a desktop Mac, Not a PB,
I write :
I use mp2000 works and newton press and paperback by David Fodor.
Paperback helped me meditate a long time on e mails. Now, Newton Press
enables me to optical character recognize books and read them with glowing
mp130 and mp2000 while I take long walks.
He writes : (I heard that it could control a Sony disk
player..but why? )
Having a free api for a disc player allows more control buttons
that fit on the disk player. Once upon a time in an apple operating
system, apple had buttons to control the seconds of starting and stopping
a cd track. I could use this to drill difficult passages in choral pieces.
Now, I can't. So, controling a cd sounds very interesting to me.
Attempt at Summary :
I use my newtons to carry reading around with me and to take notes
without making typing sounds.
I also like to learn object oriented application development which
I write on my mac and port into the newton with something that changed its
name from slurpee to sloop (I believe).
I have little tiny freeware programs to import sounds and picts
from the mac to the newton.
Newton press allows me to typeset latex documents, print them as
picts and then import them into newton press as pages. This keeps me
current in physics while taking delightful long walks without carrying a
powerbook. Check out my Albrecht101.
I think the newton is very relevant carriable for communicating
with macs.
Kindness in closing :
I appreciate Dr. Horvath's frustrations. I know that I might like
to keep names and appointments organized but if Claris Organiser and
Newton Connection Utilities crash and mess up to disorganize me, I would
be rather proud to notice them messing up. That is a serious flaw. I
recall having heard of an appointments program messing up in some place
near Washington D.C. and how they had to look for someone cleared to know
the schedual to fix it. So, I would suggest apple or newton get on the
bicycle with this. It could mean the government won't do a block buy of
these units. I suspect that these people are under great stress at end of
fiscal year and things will clear with the season.
I hope Dr. Horvath doesn't get discouraged prematurely with
newton, where instead he, like me, might instead find some great pleasure.
Date: Sat, 15 Nov 1997 14:44:53 -0500
Subject: Picture cataloguer program (Q)
Dear Digest reader,
I am looking for a simple freeware that will layout thumbnail images of all
the images stored in a folder on the screen at the same time, whether in
TIFF, PICT, GIF, JPEG format.
But I'd be happy if they were all at least one of these formats.
Also if someone has made a drag-drop utility to convert PICT images to GIF
or JPEG that would be great too.
Thank you.
Sincerely, [email protected] http://www.ameritel.net/lusers/abrody
Date: Sat, 15 Nov 1997 16:07:18 +0000
Subject: Powermac 7500 StartUp problems
Hello;
When I turn my 7500/100 (with a 200mhz 604e processor) on for the first
time in a session the system just freezes on the startup disk icon. I have
to leave it like that for 2-3 minutes before rebooting where it then
starts up OK. I have heard that this problem of reading the start-up disk
is a common problem with the 7500 model? Does anyone know if this is true
or not and why it's happening?
If you can help me out then do please drop me an email on the following address:
[email protected]
thanks
Jamie
Date: Sat, 15 Nov 1997 13:43:16 -0800
Subject: Saving Images
With Netscape, whenever I want to save an item that contains images, as
well as text, I pull down File and click "save as". When I open the file
off line no images are shown. Can I do anything to save the images as
well as the text. I am usinf a 6400/200 with Mac OS8. Thanks for a
reply.
Date: Fri, 14 Nov 1997 22:31:47 +0100
Subject: SnapScan
Boris Sch|nfeldt wrote:
> I've got an Agfa snapscan and is trying to find out what good OCR-software
> to buy. I've tryed both textbrige and omnipage in the shop, but both are
> interfering with the system 7.5.3 and OS 8 (system crash).
I have OmniPage 7 working here without problem (finally). I use a Quadra
650 with an Apple PPC upgrade card, and it used to crash before I made a
"universal" installation. Somehow, it seems to use the 68040 processor
for some tasks - don't ask me why and how this can be.
Look at
Date: Thu, 13 Nov 97 22:09:55 -0600
Subject: Thermal Recalibration and AV Drives
Does anybody know what thermal calibration is in regards to hard drives
and how that might affect the data stream coming from a hard drive?
Also, would anybody recommend a good A/V type of drive that would be good
for mastering CDs?
Jason
[email protected]
Date: Thu, 13 Nov 1997 05:59:34 -0500
Subject: Translating AppleWorks file
On November 10, Arthur Snoke wrote:
>I have files written in Appleworks written on 3.5" disks from an
>Apple 2e several years ago. I have Clarisworks v5.0, and I am having
>trouble translating them.
>I did it some years ago, using Apple File Exchange. Now with v 7.5.3
>OS on a Performa Powermac neither, I can bring up the disk contents,
>but I cannot read the file. "Get Info" tells me the file is a ProDos
>document, and when I click on it, it tells me there is no application
>named ProDos on the system. Dragging it into the Clarisworks icon does
>nothing -- it is just ignored. Trying to open it from within
>Clarisworks does not work, because Clarisworks does not even show the
>file in the selection window. I also have an LCII running os 7.1.1. I
>can transfer the file to the hardrive using AFE, but doing anything
>more crashes the
>system.
If the PC Exchange control panel is active on your PowerMac, you should
be able to mount that ProDos disk by popping it into your floppy
drive--but it sounds like you’ve gotten that far.
Reading an AppleWorks file in ClarisWorks shouldn’t be any difficulty.
I haven’t installed v5.0 yet, but for a long time CW has had three
AppleWorks translators built right in. These are named AppleWorks,
AppleWorks DB/SS and AppleWorks GS. You should see them right at the
top of the System : Claris : Claris Translators folder.
What I don’t know is what versions of AppleWorks these translators
support. Near the end of its lifespan (actually, I wouldn’t be
surprised if it’s still being sold), AppleWorks was sold or licensed or
whatever to a third party, and versions 4 and 5 were not released by
Claris. For more help, check out the ClarisWorks mailing list, which
you can subscribe to at [email protected].
Jeff Frankel
Windsor, Maine USA
"Where the woodpecker pecks
and the porcupine plays"
Date: Thu, 13 Nov 1997 08:23:02 +0000
Subject: Unimplemented Trap
I keep getting an error message when I use Simple Text: "Unimplemented
Trap" requiring a restart. What have I done to cause this? Remedy?
TIA
Best Regards
Tom
[email protected]
Date: Sat, 15 Nov 97 16:22:26 -0000
Subject: Upgrading from 7.5.3-->7.6
Hi,
I have a cd with 7.6 on it and want to upgrade my PM Performa 6400 from
7.5.3. Is there anything special I should do before or during the
update? Is it just like a System re-install proceedure? Any hints,
tips, personal experiences good and bad or suggestions would be very
gratefully accepted. Please email me personally:
[email protected]
Chris McVay
[email protected]
--Info-Mac-Digest--
