Info-Mac Digest V16 #245
Subject: Info-Mac Digest V16 #245
MIME-Version: 1.0
--Info-Mac-Digest
Info-Mac Digest Thu, 21 Jan 99 Volume 16 : Issue 245
(Q) Drive Setup and Unsupported Drives
[A] Application Switcher Applescripts (Mac OS 8.5 help viewer)
[A]: Starmax CD Problems
[Q] DOS card printing to Laserwriter Plus
[Q] MSIE 4.5 and Newsreader
Alarm Clock and Y2K
G3 PB, 12" or 14"?
Initio U2W, Softraid, Viking II LVD
Net problem with 8.5.1
Newton Battery Pack: summary of responses
Newton Battery Packs Info-Mac Digest V16 #244
Optimizing G3s
PB 5300 issues
SE30 blank Screen problem
containing gigabytes of freely distributable Macintosh software.
Email Addresses and Instructions:
the Subject line.
the Subject line.
form at before contacting us.
FTP and Web Addresses and Instructions:
* To submit files larger than 800K, email a description to
binhexed file to info-mac.org, using the userid "macgifts and the
* A full list of Info-Mac mirror sites is available at the URL below:
* Search the archive at .
Info-Mac volunteers include Gordon Watts, Adam C. Engst, Demitri Muna,
Michael Bean, Liam Breck, Hugh Lewis, Tom Coradeschi, and Shawn Bunn.
the main Info-Mac machine.
--Info-Mac-Digest
Content-Disposition: attachment; filename="Info-Mac Digest V16 #245"
Date: Wed, 20 Jan 1999 09:11:00 -0000
Subject: (Q) Drive Setup and Unsupported Drives
I have a Maxtor LXT213SY c.200Mb hard drive but can't get it to be
'bootable'.
I can successfully format it using 'Third party' formatting utilities and
install a system on it. But even when selected as the startup disk, the Mac
doesn't recognise the disk at system start and defaults to the original
system disk.
I think (and this is pure speculation) that I need to run Apple's Drive
Setup
to make the disk 'bootable', but the application reports that it can't
modify
an 'unsupported drive'.
Anybody got any suggestions?
Regards.
Bryan Tucker.
Date: Wed, 20 Jan 1999 06:15:11 PST
Subject: [A] Application Switcher Applescripts (Mac OS 8.5 help viewer)
>Hi,
>In the Mac OS 8.5.1 help viewer, under application switching are links to
>a couple of applescripts for customizing the application switcher
>floating palatte. Does anyone know where these scripts acutally reside? I
>can't seem to find them and would like to modify one to open the app.
>switcher at startup to the lower left corner, horizontal view, in order
>of launch.
>Please reply to
>Thanks,
>Scott Horton
Hi Scott,
They're at:
Macintosh HD:System Folder:Help:Mac OS Help:fp:shrd:
You can open the Dictionary of 'Application Switcher' in the Extensions
folder to find the specific parameters. There's also some Applescripts out
there that have an interface built in so you can choose the parameters
using dialogs.
Randall
Date: Tue, 19 Jan 1999 14:49:35 -0700
>of launch.
They, and other AppleScripts, can be found in various places in the Help
folder inside the System folder. They have some weird names, though. The
ones you're particularly interested in can be found at:
Your HD Name:System Folder:Help:Mac OS Help:fp:shrd:
as
AppSwitcherLowerLeft
AppSwitcherLowerRight
AppSwitcherRestoreDefaults
fpShwAppSwtchr
You can also learn fun things by looking at the Application Switcher
extension dictionary with ScriptEdit (or another AppleScript editing
application).
Bruce Carter, Division Manager Instructional Development Division
SMITC, Boise State University, Boise, ID 83725 (208)426-1851@voice
mailto:[email protected] (208)426-1856@fax
http://mentor.idbsu.edu/BruceCarter/home.html (208)384-2084@pager
Date: Tue, 19 Jan 1999 22:01:58 -0500
Subject: [A]: Starmax CD Problems
Info-Mac 1/19/99 3:32 PM
>Date: Sat, 16 Jan 1999 17:46:03 EST
>From: [email protected]
>Subject: Starmax CD Problems
>Hi Folks,
>I use a Starmax 3000/180 at work (the only Mac in an all PC shop),
>running 7.5.3 and FWB CD toolkit software. I recently tried to update to
>7.6.1 but the computer would not boot from a CD. I tried using "Startup
>Disk" and rebooting with the "c" held down, but no luck. I can tell the
>system is trying to access the cd at startup because I feel it
>spinning-up. BTW, the CD is accessible from the desktop _after_ bootup
>from the HD.
>Any suggestions on solving this problem would be greatly appreciated..
>TIA,
>Rob
I have the same machine at work and had the same problem. I created a
startup disk on a zip and use that for booting the Mac. Then I did a
clean install (I now have 8.1 on that machine). I suppose that if you are
doing a clean install you can boot from the internal hard disk as well,
but won't be able to update the hard disk driver. This could be a problem
if you use Apple's drivers, but I have used FWB's HDTC (v2.5.3) on this
machine so I wasn't concerned.
I also have found that the Apple CD ROM extension in system 7.6 is the
last one that will support the internal (IDE) CD drive in the Starmax.
After upgrading to system 8.0 and 8.1, the CD wouldn't work with the
newer driver, but replacing it with the older one works just fine. I'm
sure there is a way to use resedit to hack the driver and make it work,
but you don't have to bother. Just keep the 7.6 extension around when
upgrading or you can use FWBs CD ROM toolkit (most recent version 3.01 I
believe) which supports that CD just fine. Booting from the 7.6 install
CD was not possible for me.
Good luck,
Scott Horton
Date: Tue, 19 Jan 1999 13:57:15 -0800 (PST)
Subject: [Q] DOS card printing to Laserwriter Plus
I tried this on Apple's tech support forum, but got no response. So
I'll try here.
Problem: Cannot print from Windows 95 on a DOS card to a Laserwriter
Plus.
Configuration: Quadra 610 DOS, 486sx 25Mhz replaced by 486DX 50Mhz,
Mac OS 8.0, Windows 95.
Questions:
What type of printer should I configure Windows for? I am trying to
print from Windows 95 on the DOS card to a Laserwriter Plus. I assume
I can specify this printer for what it is, and not as an Epson. When I
try to print, this comes out:
ERROR: undefined
OFFENDING COMMAND: setlinewidth
STACK:
/Lw
Now, I know somewhere in the TIL it says, "Quadra 610 DOS + Centris
610 with 486sx (25Mhz) PC card are not compatible with Windows 95."
However, it works, possibly because I have used an online tip to swap
the chip for a 486DX/50Mhz. Everything works fine. I think this is
just a printer configuration issue.
Both Mac and DOS card have plenty of memory. Not much I can do to jazz
up the Laserwriter Plus (hey, it was free). Any ideas? Thanks.
Brian Wessels
Brian Wessels
work:[email protected]
private:[email protected]
This is my private, "permanent" email address.
Worried about Y2K? Buy a Macintosh. Y2K safe since 1984.
_________________________________________________________
DO YOU YAHOO!?
Get your free @yahoo.com address at http://mail.yahoo.com
Date: Wed, 20 Jan 1999 10:00:35 -0500
Subject: [Q] MSIE 4.5 and Newsreader
I am using MSIE 4.5 on a 6100/66 Mac with 40M of ram and
MT-NewsWatcher 2.4.4.
I have the Protocol Helpers in MSIE's Preference set to use
MT-NewsWatcher 2.4.4, but when I click on a Usenet link in MSIE, I get the
alert box " Explorer is not configured to handle news. Install M/S Outlook
Express or use the Protocol Helpers Panel in Preferences to configure
Explorer for your news application."
What am I doing wrong? Any suggestions on how to correct this?
Many thanks,
Bob G.
"If there really is a God who created the entire universe with all of its
glories, and He decides to deliver a message to humanity, He will not use,
as His messenger, a person on cable TV with a bad hairstyle." Dave Barry
Date: Tue, 19 Jan 1999 16:41:13 -0800
Subject: Alarm Clock and Y2K
Apple Computer's desk accessory "Alarm Clock" displays the year 2000 as
"0". Not even "00", but just "0". Can Apple, or someone, be persuaded
modify that DA to give a 4-digit display for the year?
(Or is there a newer version that I don't know about, which does the job?)
Date: Tue, 19 Jan 1999 16:47:24 -0500
Subject: G3 PB, 12" or 14"?
I know, I know this sounds like a snooty question but I'd really like
some input from you guys. I've had my PB 100 for the past 5 years and
it's earned it's retirement. I'm about to purchase (my wife's 50th B-Day
present to me) a G3 PB but which one? I'll basically use the new PB for
word processing (I'm a teacher) and downloading and manipulating jpegs
from my digital camera. Obviously the 14" for 2,499 with an additional
64 Mg RAM thrown in (MacMall) looks great as opposed to the 12"er for
1,999 which I thought was perfectly fine until I actually saw the 14".
The 2,499 is really pushing the price envelope. Is this just simple case
of monitor envy?
1) If I go for the 14" are there enough resources (L2 cache, VRAM)
to power the PB properly?
2) Or should I just get the 12"?
3) What's currently the best place to purchase the PB?
Thanks for hearing me out and for any suggestions that you may have.
Neal
Date: Wed, 20 Jan 1999 00:02:26 +0000
Subject: Initio U2W, Softraid, Viking II LVD
--------------45485B49AFAA1674B88A9D6B
Content-Type: text/plain; charset=us-ascii; x-mac-type="54455854"; x-mac-creator="4D4F5353"
Content-Transfer-Encoding: 7bit
Configuration
* Mac 8600/200 / 192 ram / OS 8.1
* original hd 2G on Bus o, ID 0 / driver: Mac drive setup 1.4 (Dutch
version)
* two internal viking II Lvd (U2W) 4,5 G (TP removed on both disks,
SCSI termination on SCSI cable, Bus 2 ID 4 & 6)
* PCI Initio Miles U2W on Bus 2, ID 7
Problem
* with Strata Videoshop 3.0.4 and Edit DV 1.1.1
o saving a recorded video (both small and large) to the original
HD (HFS) works perfect
o saving a recorded video (both small and large) to a single
Viking drive on the Miles card (initialized with Mac Drive
Setup in HFS format and with the mac driver installed) works
perfect
o saving a small or large recorded video to a single Viking
drive on the Miles card (initialized with softraid 2.1.5 in
HFS format and with the softraid driver installed) doesn't
work
o saving a recorded video (both small and large) to the Viking
drives on the Miles card in RAID O or 1 (initialized with
softraid 2.1.5 in HFS format and with the softraid driver
installed) doesn't work
* with MacBench 5.0
o All MacBench drive tests works fine on a single Viking
initialized with mac drive setup
o random write 512 test on a single Viking II initialized with
softraid and with the softraid driver installed doesn't work.
I get the same situation in raid 0 and 1
Are my drives not compatible with softraid?
Is the Initio card the problem
Is MacBench, Strata Videoshop, Edit DV the cause?
!!!! Strange: Apple video player 1.7.2 works fine in all situations!!!!
Peter Dolle
Content-Type: text/html; charset=us-ascii
Configuration
version)
two internal viking II Lvd (U2W) 4,5 G (TP removed on both disks, SCSI
Problem
saving a recorded video (both small and large) to the original HD (HFS)
works perfect
saving a recorded video (both small and large) to a single Viking drive
on the Miles card (initialized with Mac Drive Setup in HFS format and with
the mac driver installed) works perfect
Viking drive on the Miles card (initialized with softraid 2.1.5 in HFS
format and with the softraid driver installed) doesn't work
the Viking drives on the Miles card in RAID O or 1 (initialized with softraid
2.1.5 in HFS format and with the softraid driver installed) doesn't
work
with MacBench 5.0
All MacBench drive tests works fine on a single Viking initialized with
mac drive setup
random write 512 test on a single Viking II initialized with softraid and
with the softraid driver installed doesn't work. I get the same
Peter Dolle
--------------45485B49AFAA1674B88A9D6B--
Date: Wed, 20 Jan 1999 15:59:29 +0000
Subject: Net problem with 8.5.1
Can someone help with this problem, getting on to the net reliably?
(PowerMac 7300, running MacOs 8.5.1)
I have run TechTool Pro and Disk First Aid, Rebuilt the desktop, and
zapped the PRAM. I have removed the operating system (8.5.1)and
reinstalled MacOs 8.5 and re-updated to 8.5.1.
But even running with the original bare system, with NO additional
control panels or extensions added, the following intermittent failure
happens. Not every time I start up, but often. When I start my Mac up,
sometimes my ethernet connection comes up (fine), and sometimes it
doesn=92t.
In the latter case, I open Appletalk and find it set to Ethernet. It may
also say . If I wait, sometimes it will
find a zone on our intranet, and then I can re establish contact with
the network. Other times the message changes to .
In this case I have to restart, and perhaps I will be on the net. It is
unpredictable.
I don=92t think the fault is in the hardware, because when I start up on
MacOs 8.1 (on a different partition of the same hard disk) it always
works.
So what should I do now? Is there a problem with Open Transport (2.0.2)?
Should I try substituting the Open Transport extensions from System 8.1
and seeing if they work better? Mike
Michel Treisman
Department of Experimental Psychology
South Parks Road
Oxford OX1 3UD
UK
Tel +44 (0) 1865 271319
Fax +44 (0) 1865 310447
Date: Tue, 19 Jan 1999 16:03:16 -0600
Subject: Newton Battery Pack: summary of responses
Thanks to all who responded to my question on replacement rechargable
battery packs. Here is a summary of what I received in reply:
* I have a Newton MP 120; this was left out of the original note, and
changes the answer to the question of how to get spare batteries.
* Sources for "vintage" Apple/Newton parts are:
- http://www.sunrem.com. You can get spare battery packs for the 2100,
but for the 120 you must exchange the battery you have (can't just order
a spare).
- One individual has used Rayovac rechargables and nothing else on his 2100.
- Another writes: "FWIW, I bought 4 NiCad AAA batteries, put them in the Alkaline
battery holder, I had and put a small piece of tape in my MP100's
battery compartment to hold the small blue sensing switch in, at the
end of the compartment."
- (http://www.smalldog.com) has batteries for the MP 2100.
- Most vendors do have battery rechargers and power adapters available for
all models.
A S Hodel Assoc. Prof. Dept Elect Eng, Auburn Univ,AL 36849-5201
On leave at NASA Marshall Space Flight Center (256) 544-1426
Address:Mail Code ED-13, MSFC, Alabama, 35812
http://www.eng.auburn.edu/~scotte
Date: Wed, 20 Jan 1999 02:38:23 -0500
Subject: Newton Battery Packs Info-Mac Digest V16 #244
quoting Info-Mac and possibly previous message abstract:
>Date: Fri, 15 Jan 1999 23:20:31 -0500
>From: Dave Reiser
>>The rechargeable battery on my Newton is beginning to age; unfortunately,
>>I didn't think to order spares when Apple jettisonned the Newton. The
>>Newton manual indicates that standard NiCad rechargable batteries should
>>not be used, so I apparently need to find an alternative. I
>>was unable to find Newton batteries listed at the Apple Store, MacMall and
>>MacWarehouse. Are there any suggestions out there (less expensive than
>>a Palm Pilot :-) ) for replacement battery packs for a Newton?
>A couple weeks ago, anyway, Smalldog (http://www.smalldog.com) had more
>than a dozen left.
>Dave
>Dave Reiser
>[email protected]
I have sucessfully used NiMh Individual cells with very good results.
The cells are from Radioshack and a NiMh charger as well is used to
charge them. I am getting 5 or more times the performance of the NiCad
cells supplied from Apple. No problems with usage after 4 months.
>--- (_o^o_) ----- a wise ass -----
Subject: Optimizing G3s
At 5:10 PM -0400 on 1/18/99, Beth Ernst wrote:
> I need to optimize the drives on our G3s. I've always used Nortons Speed
> Disk in the past but have read several negative articles on the new version.
> We are running OS 8.1, does anyone have any recommendations or suggestions,
> good or bad experiences they can share with me on optimizing. Only one of
> our machines is formatted HFS Plus, the rest are all Standard HFS.
Norton Utilities for the Macintosh (NUM) 4.0 handles HFS+ as well as
standard HFS drives. I think NUM is all we have for optimizing (not
TechTools or anything else).
Best to also download Symantec's patcher for Norton Disk Doctor 4.01 to see
if you need that, too. Hope you don't because it's a pain.
Ted Logan
Logan Writing, Inc.
Cleveland, Oklahoma
Date: Tue, 19 Jan 99 15:02:59 -0800
Subject: PB 5300 issues
To: Info Mac
Question-
I've been asked to resolve a minor issue with a PB 5300,
unfortunately none of the manuals can be found.
Various sources state the PB 5300 can be connected to another Mac
(desktop) via a SCSI type cable with the result the PB's HD will
appear as an external disk to the other Mac. I found what I believe
to be the correct cable (short - 10-11", grey) shut down
everything, plugged in, with a terminator between the SCSI cable
from the Q630 and the grey PB cacble, then restarted the PB. The PB
screen is blank until I start the other Mac (Q630), at which time
two arrows appear. Afterwards, the Q630 seems to stop.
So what I do wrong? I gave the PB a SCSI address in the SCSI Disk
Mode control panel, no other SCSI devices during the test.
Both Macs run 8.0, though the SCSI control panel on the PB is 7.3.2.
Any pointers, hints, a manual?
As always,
Ed Wright JPL/NAIF Team
Date: Tue, 19 Jan 1999 13:31:02 -0700
Subject: SE30 blank Screen problem
My SE30 starts up with a normal chime and hard drive noise, and the screen
lights up but always remains blank (all gray). The hard disk is fine (I
tested it in another Mac). Any suggestions on fixing this?
--Info-Mac-Digest--
