Info-Mac Digest V18 #11
Subject: Info-Mac Digest V18 #11
MIME-Version: 1.0
--Info-Mac-Digest
Info-Mac Digest Thu, 18 Jan 01 Volume 18 : Issue 11
(Q) Stickies Window Hack? [repost]
[*] FileBuddy 6.0.3 - Japanese Version
[*] Smart Scroll 3.7.1J - Japanese Version
[*] SwitchRes 2.5J - Japanese Version
[Q]Redundant software on info-Mac?
Hayes 56k + Fax Updater
Info-Mac digest and Eudora
Information Transfer (R)
Laserwriter 16/600 & PoerBook G3
Screen capture
where to post message?
from the new address.
and Chris Pepper.
--Info-Mac-Digest
Content-Disposition: attachment; filename="Info-Mac Digest V18 #11"
Date: Thu, 18 Jan 2001 10:50:14 -0600
To:
Subject: (Q) Stickies Window Hack? [repost]
If no one can point me to the patch, is there another way to arrange
Stickies' windows instead of manually placing them where I want them?
Thanks in advance,
Matthew Schmeer
You know you can manually place all the collapsed windows along the left
side of the screen (or wherever you want them) . When you open one, drag it
by the bar to a more convenient location for text entry. Now collapse it and
it will return to the last location it was in the collapsed position and the
next time you open it it will return to the last position it was in when in
its open state.
Joseph Pilon
Date: 18 Jan 2001
To:
Subject: [*] FileBuddy 6.0.3 - Japanese Version
This is the Japanese version of the FileBuddy package.
File Buddy is quite simply the most powerful and popular high-level file
utility available for your Macintosh.
File Buddy 6 requires a PowerPC-based Macintosh with System 7.6 or
later. If your system does not meet these requirements, you may be able
to use File Buddy 5.
*View and edit a wide range of file and folder information in the info
window.
*Create droplet applications that automatically apply changes to items
dropped on them, including the contents of folders.
*Find files and folders using an extensive set of search criteria.
Enhance file searches with plug-ins that extend file search capabilities.
Conveniently perform a wide variety of actions on found items. Make File
Buddy your default file finding application using the File Buddy CP
control panel.
*Modify the names of multiple files at once. For example, remove ".txt"
from the names of a group of files.
*Much, much more...
Changes:
*File Buddy now displays an alert if an error is encountered while
displaying the online help, and adds the option to move the File Buddy
Help folder to the system's Help folder in addition to copying it.
Fixes:
*The custom install to install only the File Buddy application would not
install all of the online help. Fixed.
*Erasing unused space on large volumes could still cause File Buddy to
hang. Fixed better.
*Check Aliases could report one good alias as unattached. Fixed.
*The Connect button in the Unattached Aliases window was not relocating
when the alias list was resized. Fixed.
*The View Icon Family window no longers draws 1-bit icons in the spaces
for 32-bit icons if 32-bit icons are not supported.
*Expanding the list of disks in the Find window could cause a crash.
Fixed.
*Information in the File Buddy CP control panel has been updated.
*A few people have reported that File Buddy crashes when they try to use
the desktop rebuilding command. We believe what may be happening is a hang
that results from a process that will not quit. That code has been
rewritten to prevent hanging if a process won't quit, and it no longer
tries to get background processes to quit.
[Archived as /info-mac/disk/file-buddy-603-jp.hqx; 1555 K]
Date: 18 Jan 2001
To:
Subject: [*] Smart Scroll 3.7.1J - Japanese Version
This is the Japanese version of the Smart Scroll package.
Smart Scroll: Scrolling speed control, Proportional scrollbar tabs and
Live scrolling.
Smart Scroll allows setting a comfortable Scrolling Speed in all
situations and for all Mac models. Users of fast G3 and G4 Macs may now
select text past the edge of a window before it speeds by, as well as
navigate long menus with ease!
And while Apple's "Smart Scrolling" concerns mostly the Finder, the
original Smart Scroll brings Proportional Thumbs and Live Scrolling to
applications such as Netscape, Emailer, AppleWorks, Word, and most
system add-ons such as control panels.
Version 3.7.1 adds support for Mac OS 9.1, runs under Mac OS X's
Classic, and fixes a few minor issues.
Smart Scroll runs on Mac OS 9.1 and previous versions (going back to
System 7.0). It is shareware, so you can try it for free then buy only
if you like it. Registered users of previous versions may upgrade for free.
[Archived as /info-mac/gui/smart-scroll-371-jp.hqx; 230 K]
Date: 18 Jan 2001
To:
Subject: [*] SwitchRes 2.5J - Japanese Version
This is the Japanese version of the SwitchRes package.
Rated 5 Cows by Tucows (highest rating)!
SwitchRes is a little utility that will allow you to switch the
resolution of all your monitors. You can access to all the resolutions
of all your displays in a simple, customizable menu. SwitchRes
incorporates features from the Monitor Resolution, Monitor BitDepth, and
Video Mirroring Control Strip Modules bundled with your system. You can
use its menu in the Menu Bar, use its provided Control Strip Module, or
click on the Finder Desktop with its Contextual Menu Plugin.
SwitchRes has an extensive list of features:
*You can show and use all available resolutions of your video card, not
just those limited by your monitor. For example, 20 video modes are
available on my PowerMac 7300 internal video board. Enjoy your Apple 15"
monitor in 1024 x 768, or 640 x 480 in 120Hz !
*SwitchRes is totally configurable. You can define which resolutions are
really accessible, and which will require a confirmation.
*You can also create display sets which will allow you to change the
resolution and the depth of all your monitors with just one mouse click,
or just one key. With this new version, you can add scripts to display
sets. That gives SwitchRes the ability to launch a script with just one
key, or when an application is launched...
*You can assign a specific set to an application, so that every time you
use this application, your Mac will automatically switch to your
predefined resolutions. You will find this extremely useful for most
games.
*You can save the position of the icons and the windows on your desktop,
independently from one resolution to the other, unlike the Finder. The
configuration is restored at startup.
*You can script SwitchRes for resolutions and color depth changes.
SwitchRes is even recordable: When SwitchRes is running, every
resolution change is automatically recorded in the script editor
[Archived as /info-mac/gui/switch-res-25-jp.hqx; 674 K]
Date: Thu, 18 Jan 2001 07:41:15 -0500
To: The Info-Mac Network
Subject: [Q]Redundant software on info-Mac?
At 10:36 PM -0800 1/14/01, you ([email protected]) wrote:
>>>I was just wondering why there seems to be so much redundant software
> >>on info-mac?
>>Trying to make a better mouse-trap??What if Apple said"Adobe has the
>>film editing field sewn up with Premiere and After Effects,why
>>bother with Final Cut Pro?"
>Ok, sure, but what I am trying to say is the redundant software I
>have found on Info-Mac that I am talking about is inferior to the
>other software available!
>How can you build a better moustrap if you don't bother to find out
>how the original moustrap is built?
One man's meat/poison...
1. Sometimes what might seem to be an inferior product might
represent a different, ultimately worthwhile approach.
2. One thousand pieces of junk may be uploaded and then one gem is
found amid them.
3. The confidence to expose coding or pose answers may reinforce and
encourage the efforts of a budding programmer. Don't stifle 'em.
4. The willingness to invite peer review is a _good thing_.
5. "inferior" is an opinion probably unsupported by the programmer in
question. But his over-inflated view of his own coding would remain
unchanged in the absence of user feedback (or the feedback implicit
in a total lack of interest in the product).
6. A piece of "inferior" software may include one feature that can be
incorporated and expanded upon by the developer of one of a
_superior_ app.
7. Finding out "how the original moustrap is built" can destroy the
clean-room approach to solving a problem.
None of the above are written in stone. It's just that _sometimes_
the approach that leads to what you consider to be inferior CAN lead
to something better, or different. And then that one item is worth
oodles and oodles of the junk that went before...
Date: Thu, 18 Jan 2001 10:23:28 -0800
To: [email protected]
Subject: Hayes 56k + Fax Updater
My ISP changed servers recently. Now I can't connect to their roam
numbers. Need this updater.
FILE NAME: V1120MAC.SEA.HQX For Macintosh ACCURA modems with version
0.519 firmware.
Is Hayes 56K Beta Firmware:
This beta code allows a K56Flex Hayes client modem to be interoperable
with all Rockwell-based and Lucent-based K56Flex servers, providing that
the servers are also running code that complies with the K56Flex 1.1
specification.
Hayes is bankrupt and Zoom says they did not purchase any Macintosh
updaters from Hayes, only Windows. (!) So, if anyone has this file
laying around, could you send it? Thanx.
Richard...
Date: Wed, 17 Jan 2001 21:17:36 -0500
Subject: Info-Mac digest and Eudora
At 10:33 -0500 1/16/01, Glen Hawkins wrote:
>Something that annoys me and I cannot work out why it is happening.
>Info-mac digest comes to me in a contents page and then an attached
>eudora file that I can open up like any normal e-mail file with the
>actual messages listed. But after this has happened I see that Eudora
>then has placed a new mailbox entry into my menu bar of the issue of
>info-mac digest. It is the only program that does this and it stuffs
>up my mailboxes regularly. Can I get a rid of the mode that is doing
>this?
Sure. In the "Settings" window, "Attachments" panel, uncheck the box labelled "Receive digests as MIME attachments." If I'm remembering correctly, that should do it.
+- Saint John -+
| "The Posby goes into a trance |
+-- In which it does a little dance." (E. Gorey) --------------------+
Date: Thu, 18 Jan 2001 12:24:49 +0100
To: [email protected] (Roland & Jodi Emond)
Subject: Information Transfer (R)
Roland & Jodi Emond wrote:
> I have been using a Power Mac 7200/90; and recently purchased an Imac
> DVD SE (500 MHz). Is there a way I can connect the two via a network
> cable to transfer about three years worth of infomation without going
> through the trouble of downloading everything on a Zip drive.
You need a cross-over ethernet cable (I think the 7200 has Ethernet!)
and probably a transceiver from AAUI to 10base-T. Then just use
filesharing to mount one drive on the other computer.
Christian.
Christian F. Buser, Hohle Gasse 6, CH-5507 Mellingen (Switzerland)
Look at
Korruption ist die Autobahn neben dem Dienstweg (H. Nahr).
Date: Thu, 18 Jan 2001 15:57:11 -0500
To:
Subject: Laserwriter 16/600 & PoerBook G3
I am looking for a way to use my Apple Laserwriter 16/600 with my PowerBook G3. I considered a USB to Serial adapter but found that the adapters on the market (do far as I know) will not connect to the LaserWriter. Keyspan tells me that that the reason is that this printer supports Localtalk, a proprietary Apple protocol.
What would you recommend to make my machines work together?
John Hutchens
Director
Arts and Sciences
252-321-4383
Date: Thu, 18 Jan 2001 16:51:05 +0100
To: "'[email protected]'"
Subject: Screen capture
Hello,
I'm looking for software to capture my movenments on te screen into a
quicktime movie. A bit like adobe uses to make their tutorial movies.
Can someone help me
rik steuperaert
Date: Thu, 18 Jan 2001 12:31:04 -0500
To:
Subject: where to post message?
First, thanks for this resource from which I've learned so much and
downloaded so many fine things over the years.
The 90 day warranty on my G3/400 (OS9.1) PowerBook has just ended (of
course), and I can't figure out why most of the time it wakes from sleep
just fine, but when asleep for longer periods, it doesn't wake up.
I'm pursuing Apple's Technical Note #58645, "USB Enabled Macintosh:
Troubleshooting Sleep Issues", but in case that doesn't provide the
solution, I'm trying to figure out where to post some requests for help.
Here's your chance to tell someone where to go... is this more likely a
hardware thing? OS? should I just find a general PowerBook list?
Thanks in advance,
Wendy Farkas
_________________________________________________________
Do You Yahoo!?
Get your free @yahoo.com address at http://mail.yahoo.com
--Info-Mac-Digest--
