maclink-pc-8-formats.txt
Download: http://archive.info-mac.org/cmp/macgzip.hqx
The MacGzip package provides four files: the M-Files gunzip.m
and gzip.m, and the AppleScripts gzip and mat2front.
They are used to gzip and un-gzip files using MacGzip,
the Macintosh version of gzip. MacGzip can be obtained
from a number archive sites, including:
http://hyperarchive.lcs.mit.edu/HyperArchive.html
Examples of usage are given in the M-Files.
This may be freely distributed as is.
Joseph C. Slater
FAQ - How do I convert from PC to Mac and Mac to PC?
DataViz MacLinkPlus 8.0 is one of many solutions, if others exist that can
do all the following for less I would like to know:
1. Will convert to/from the most popular versions of MS-Word and Word
Perfect including WP 6.0 PC, MSWD 6.0 Mac, MSWD 6.0 PC, WP 3.0 Mac, MSWD
5.1 Mac.
2. Transfers data over serial RS232 cables (included with software). Will
translate before or after transfer.
3. Given two modems and two phone lines, will transfer data to be
translated to guest machine, or translate before sending to guest machine,
and transfer data over there.
4. Includes Apple PC Exchange 2.0 as part of package.
5. Includes DataViz FileView.
6. Translates before transfer to, or after receiving files from non-Windows
