StuffStuff.sit.hqx
StuffStuff.sit.hqx
Download: http://archive.info-mac.org/cmp/stuff-stuff.hqx
This package has 3 applications that I use for preparing uploads and
such. I keep them all on the desktop to make my life a little easier.
The applications (Stuff, Hex and Both) are drag and drop applicatons
that will stuff, hex and both stuff and hex anything dragged on to
them. Also included is a fourth file which is a empty folder. You
should take the custom icon off of it and put it on an alias to the
Stuffit Engine which can then replace the folder. Then you will have
4 icons that only take up the place of one, yet will perform all the
functions you need to upload and download files.
Chris Owen
