This Phader is a fun little AOL/AIM utility that allows you to chat/IM more
colorfully.
You can control the style, font, size, and many other aspects of the text,
but most importantly, you can gradient your text! You can send messages
that smoothly change color from red to yellow to green, or whatever colors
you choose!
For more information check out http://mike.axisproductions.com/phader/
