AppAxe is a control panel that allows the user to define "hot keys" to
quit certain applications. AppAxe can quit just the Finder, everything
but the finder, and everything but the front application. AppAxe also
allows application switching from the keyboard via command-tab.
AppAxe only requires system 7.0 or greater.
You may distribute my control panel in any way that you want.
