BatteryAmnesia 1.5.2
Download: http://archive.info-mac.org/cfg/battery-amnesia-152.hqx
BatteryAmnesia 1.5.2 for PowerBooks
Author's email address: [email protected]
BatteryAmnesia is a utility for any PowerBook that uses a nickel-cadmium
(NiCad) or nickel-hydride (NiMH) battery. Over time, these batteries are
susceptible to a "memory effect", which can reduce their battery capacity.
The memory effect can be cured by fully discharging the battery before
recharging it.
BatteryAmnesia provides a safe, fast and automatic way to deep discharge
your PowerBook's battery. BatteryAmnesia bypasses the low battery warning
dialogs, and prevents the "soft" sleep brought on by those dialogs.
Instead, BatteryAmnesia will run your PowerBook's battery down until the
"hard" hardware shutdown occurs, which is at a lower voltage. This
provides the best discharge possible without an expensive external battery
conditioner.
Version 1.5.2 contains the following enhancements:
- Fixes Mac OS 8 compatibility bug.
Shareware; $10 registration fee suggested. See enclosed docs for more
information.
It can be downloaded from (http://members.aol.com/jbkezer/shareware.html).
Jeremy's home page: http://members.aol.com/jbkezer/
Macintosh shareware: http://members.aol.com/jbkezer/shareware.html
