Be OS Startup 1.2
Be OS Startup 1.2
Download: http://archive.info-mac.org/cfg/be-os-startup-12.hqx
Be OSô Startup 1.2
A great startup for all Macs, I repeat "Macs" and not those stink'en
IBM's.
If you like like this startup, then give me an e-mail at
If you want to actually use this startup you will need the following:
Mac OS 7.5 (or later) but not OS 8.0 ResEdit Finder
Step 1: Open up the document called Be OSô Startup 1.2 RSRC
Step 2: Click on the PICT resource
Step 3: Copy it!
Step 4: Open up a copy of System 7.5 Update
Step 5: Paste it!
Step 6: Click on yes when it asks you
Step 8: Swap your System 7.5 Updates and restart
Step 9: Hopefully you will see your cool Be OSô Startup
Note: This is freeware, so if this startup in any way or form messes up
your computer don't put the blame on ME! It works fine on my PowerBook
Duo 2300c, Macintosh LC and Macintosh Performa 580CD, but I don't know
about any other machines.
