Bridge 1 Plug-in 2.0 for Sherlock (Japanese)
Download: http://archive.info-mac.org/cfg/bridge- ... -20-jp.hqx
Bridge 1 Software Plugin for Sherlock and Sherlock 2
Both the plug-in and the site searched are in Japanese.
This is a plugin for Apple's Sherlock search program that comes with
Mac OS 8.5 and newer. It allows you to use Sherlock to search the Bridge 1 Software
site at http://www.bridge1.com. This plug-in is freeware.
