Clean-Install Assistant 1.53 moves your additions to a new System Folder
Download: http://archive.info-mac.org/cfg/clean-i ... nt-153.hqx
Clean-Install Assistant: version 1.5.3, May 29, 2002
Clean-Install Assistant makes it easier to migrate third-party and
personal items to a new Clean-Installed System Folder, and it may also be
used to:
Save space and backup your valuable additions and preference files
only, instead of the whole System Folder.
Install the same set of additions on multiple Macs.
Remove extra files and folders from your System Folder to restore it
to a previous state: you can take a =8Csnapshot=B9 of the System Folder
and have Clean-Install Assistant extract any items added since.
v1.5.3 allows moving files from Mac OS 9.2.2 to a newer Mac OS version,
or to/from 9.2.2 and previous versions.
It is free for personal and educational use.
You may download the latest version or get more info from
