delta_xy_30.sea.hqx
delta_xy_30.sea.hqx
Download: http://archive.info-mac.org/cfg/delta-xy-30.hqx
delta xy 3.0 (C)1990-1997 by Eric V. Curtis All rights reserved
delta xy is a FREE mouse coordinate measurement program. It
allows you to make precise measurements of just about anything
on your computer's monitors. It can also show you the ASCII
character and key codes for most of the keys on your keyboard,
and the RGB values of any pixel on your monitor. All values
can be copied to the clipboard and viewed in either decimal or
hexadecimal.
This is a great tool for HTML and AppleGuide authors!
New in this version:
* Clicking and dragging the mouse draws a box on screen to make
it easier to measure rectangles.
* Rectangles can be viewed as (left,top,right,bottom) or
(top,left,bottom,right).
* Rectangle coordinates are automatically copied to the
clipboard.
* RGB colors can now be viewed as either 8-bit or 16-bit values.
* A color swatch helps you measure small areas of color.
* Can have delta xy attempt to bring itself to the foreground.
Eric Curtis
