MakeItGrow 2.4
MakeItGrow 2.4
Download: http://archive.info-mac.org/app/make-it ... 4-demo.hqx
MakeItGrow 2.4 is a garden layout package for your Macintosh. It will allow you to lay out a garden up to 200' x 200', using 96 of the most common types of vegetables, herbs, and fruits, 100 common flowers, and 44 water lillies, rushes, and grasses. Each icon is drawn in the correct scale for the spacing required for the plant. The program also supports line drawing in eight colors, for garden boundaries, etc, plus a wide selection of fill patterns and the ability to draw circles, rectangles, and rounded rectangles, as well as text entry (with support for font, size, and style selection), in either the vertical or horizontal mode.
The grid is fixed at 6" per square, or 15 cm, allowing for a 200'x200', or about a 65x65 meter plot.
* Zone Map
* User database support for three types of data:
[1] New Pests
[2] New Plants
[3] Result notes for each plant tried.
* Note window for each plot
* Importing of plants
* Companion Plant checking
* Zoom (Max 16:1)
* Plaintalk (if installed)
* Select and move items
* Balloon Help
* Printing (both vertical and horizontal)
* Floating Palettes for selection of plants
* Unlimited windows (within available memory)
* Exporting of plots as either PICT or to the clipboard
* Creation of Estimated Yield based on the number and type of
plants in the plot
* Drawing of lines, circles, rectangles with fill patterns
* Creation of a text list (export all text entered in the plot)
* Text entry (vertical or horizontal), with support for font, size,
and styles
* Live palettes - see the plant names by just passing the cursor over the buttons
* Rulers displayed in either cm or inches
* Information on companion planting
* Information on pests and diseases
* Backround information on most edible plants
* Layers (8)
Changes from version 2.3:
Added about 50 more flowers.
Added Zone Map.
More information on the program can be seen at my web site,
