Title: DoubleTouch
Version: 2.3
=== Description ===
Using DoubleTouch, you can shade window by keyboard operation.
How to use is very easy. It's only pressing key twice as double-click.
=== Other minimum requirements ===
PowerMac / PowerBook / iMac / iBook
Mac OS 8.1 or later
=== What's new ? ===
- OtherWindowsKey -
This key is for shading all windows except front window.
- CleanDesktop -
CleanDesktop is changed from "Finder Option".
DoubleTouch after clicking desktop, you can do the following.
- Shade all Finder's windows
- Hide all visible applications except Finder
It is useful when you find icon on desktop !
CleanDesktop has option to show hidden application by
CleanDesktop.
=== Fixed Bugs ===
- A wrong message -
When using non-registered copy of DoubleTouch vers2.2.2 over 10 days,
DoubleTouch displays a message. But this mesage is wrong.
This message is "DoubleTouch failed to remve codes".
It is essentially right that DoubleTouch shows message for
non-registered user in this case.
=== Changes ===
- HoldKey's work -
Until vers 2.2.2, if you set HoldKey, you have to press when you
use DoubleTouch. For example, it is needed when you want to shade
all windows by AllWindowsKey.
Since this version (2.3), if you set HoldKey, this key is just needed
when you shade front window.
i.e. When you use AllWindowsKey or OtherWindowsKey with DoubleTouchKey,
you don't have to press HoldKey if you set it.
- Remove DialogOption -
It was to shade windows behind dialog. I feel it is not useful,
so I removed it.
- No trap patch -
DoubleTouch don't have any trap patches.
Osato Utility Room
mailto:[email protected]
http://www06.u-page.so-net.ne.jp/ga2/so ... index.html
