Reply-To: [email protected]
Subject: Info-Mac Digest V14 #67
To: info-mac-list
MIME-Version: 1.0
--Info-Mac-Digest
Info-Mac Digest Wed, 20 Mar 96 Volume 14 : Issue 67
[*] "Kill The Cookie"
[*] ComboBox 1.1.1
[*] ComboBox 1.1.1 Source
[*] Drop Attribute 3.0.0
[*] Flies After Dark
[*] Formula 1 1.1.9
[*] Formula 1Lite
[*] GameCheater Demo Submission
[*] HangmanPlus-v4.0.sit.hqx
[*] Heritage 3.0.1
[*] HORIZON
[*] HTML Markup 2.0 - the ultimate text to HTML experience
[*] HTML Viewer 1.2.1
[*] Jon's Commands 1.5.1
[*] Mac*Chat#106 (2 msgs)
[*] Mac-FTP-list-html Version 4.0.8
[*] MacISAR
[*] Manual Maker 2.0
[*] PrintUseMonitor 3.2
[*] Shakespeare Stack - Timon of Athens
[*] SingleNumber 1.1.6
[*] Smart Dubbing, Inline streaming GIF Web video
[*] SndSampler 2.7
6100s, DOS cards, and 7.5.3
7.5.2 Update Comments
[A] Deleting files by single keypress and Finder not showing full
filenames
[A] Where to find info about MS ClipArt Gallery problems
[C] First impressions on 7.5.3
[Q] How fast is a Performa 6300?
[Q] Netscape -> Resource fork errors?
[SUMMARY] Performa won't boot - another battery problem; worse???
ARA question
At Ease with System 7.5.3 (Update 2.0)
base64 encoding: how decode?
CH Flightstick Pro and Marathon #1
Clobbered BTress ANSWER
Database of Info-Mac messages
filenames
DO NOT BUY MEGAHERTZ PC MODEM FOR MAC!!
EasyView and Carpe.Diem (Q)
Eudora's JH Icon (was: Eudora ack)
Face Folder Icon, how?.....
GV-faxsoftware v2.5.3 & M$ Word 5.1a (2 msgs)
info-mac wais database off the air for up to a month
Looking for a utility
MO Drive for PB5300 - Myth!
Phantom file
Power Computing
Problem With Zip Drive and Nikon Scanner
Speed Access 1.1.2 still crashes the system
Stufft Browser ?
Sys 7.5.3 (One more C)
System 7.5.3 & SAM (A)
System 7.5.3 (C) (4 msgs)
System 7.5.3 where to get it
System 7.5.3 won't work with my LCIII
What's the Skinny on SoftWin 3/95?
what is a listserv for the ietf...
Win '95 on DOS compatibility card (2 msgs)
Gordon Watts, Liam Breck, Igor Livshits, Adam C. Engst
Files for inclusion:
and upload it to:
--Info-Mac-Digest
Content-Disposition: attachment; filename="Info-Mac Digest V14 #67"
Date: Wed, 20 Mar 1996 02:36:44 -0800
Subject: [*] "Kill The Cookie"
Greetings,
This simple little applet deletes the "MagicCookie" file from the
Preferences folder. As you know, this file is suspect in that it may allow
for security breaches into a users computer, especially if you are using
Java. Both Netscape and Internet Explorer uses the "MagicCookie" file to
store sensitive information which WWW sites and hackers can access. The
reason I created this applet was because these browser programs will
continually recreate this file periodically if a WWW site calls for it to
do so; therefore, this little applet gets around the tedium of manually
deleteing this file over and over.
Doug Unruh
[Archived as /info-mac/comm/tcp/web/kill-the-cookie.hqx; 8K]
Date: Wed, 20 Mar 1996 02:36:24 -0800
Subject: [*] ComboBox 1.1.1
This package contains Pensacola Christian College's freeware
ComboBox v1.1.1 external area for 4th Dimension.
OVERVIEW
The idea behind ComboBox is to provide an easy way for users to choose
an item from a list. 4th Dimension provides Choice Lists for this
purpose, but the current implementation has several problems.
ComboBox addresses these user-related problems while providing a
programming interface that allows the area to adapt to practically any
look and feel the designer wishes.
NEW WITH THIS RELEASE
Kept ComboBox areas from "swallowing" the escape key. This change
was necessary to allow the Customizer settings to work properly when
the escape key is assigned to the "Cancel Layout" function.
Fixed a crashing bug revealed with Charlie Rieman's "Less-Obnoxious Bus
Error" control panel.
Fixed a bug that caused some of a layout's text fields to display
improperly in the design environment
Compiled with better optimizations, reducing the size of the FAT
version by about 1K.
[Archived as /info-mac/dev/a4d/ext/combo-box-111.hqx; 57K]
Date: Wed, 20 Mar 1996 02:35:17 -0800
Subject: [*] ComboBox 1.1.1 Source
This archive contains the source code to version 1.1.1 of Pensacola
Christian College's ComboBox External Area for 4th Dimension.
[Archived as /info-mac/dev/src/combo-box-111-c.hqx; 187K]
Date: Wed, 20 Mar 1996 02:35:02 -0800
Subject: [*] Drop Attribute 3.0.0
Awesome type/creator/attribute changer. Lets you change type's &
creator's, modify attributes, map filename extensions to Mac file type's
& creator's, and even create custom self-running Attributelets for your
common operations! Fully multi-threaded so it runs great in the
background and never hogs the CPU. $10 Shareware.
[Archived as /info-mac/disk/drop-attribute-30.hqx; 201K]
Date: Wed, 20 Mar 1996 02:38:42 -0800
Subject: [*] Flies After Dark
[Archived as /info-mac/app/ss/flies-30.hqx; 6K]
Date: Wed, 20 Mar 1996 02:37:35 -0800
Subject: [*] Formula 1 1.1.9
Formula 1 is a communication module that improves the performance of
point or BBS programs. F1 can be used as a replacement of TabbyNet and
Call modules for Tabby and Copernicus, but it can be used with
CounterPoint, MacWoof, Alice, Pizza and Aeolus too.
This Demo is fully functional but has these limits:
- The application will expire after November '96
- F1 will make only one call for each events
- A session cannot be longer than 10 to 15 minutes (random value)
Steve Ebener
Greyland - 541/744-0568 - [email protected]
Macintosh Consulting, Diagnostics, & Repair
[Archived as /info-mac/comm/bbs/formula1-119-demo.hqx; 522K]
Date: Wed, 20 Mar 1996 02:38:01 -0800
Subject: [*] Formula 1Lite
Formula 1Lite is a communication module that improves the performance of
fidonet point. F1 can be used as a replacement for the Call module of
Copernicus, but it can be used with CounterPoint, MacWoof, Alice and
Pizza too.
- It will stop working after 30 days from the first installation
- The application in any case will expire after November '96
- F1 will make only one call during a event
- A session cannot be longer than 2 to 15 minutes (random value)
Steve Ebener
[Archived as /info-mac/comm/bbs/formula1-119r4-lite-demo.hqx; 573K]
Date: Wed, 20 Mar 1996 02:33:57 -0800
Subject: [*] GameCheater Demo Submission
Stacy Pennington
http://www.beale.com
[Archived as /info-mac/game/game-cheater-20-demo.hqx; 91K]
Date: Wed, 20 Mar 1996 02:34:46 -0800
Subject: [*] HangmanPlus-v4.0.sit.hqx
Here's my latest update to Hangman Plus. Yes, you have my permission (and
my thanks) to include it on your Info-Mac Archives CDROM.
HangMan Plus v4.0! Another exciting version of that classic game. Fun for all
ages. Loads of categories, tons of words. Enter your own words or use
vocabulary lists. Digitized sounds. Colorful and non-violent. Please give it
a try. Thanks! Site License available. (Free CDROM with registration!)
[Archived as /info-mac/game/word/hang-man-plus-30.hqx; 228K]
Date: Wed, 20 Mar 1996 02:38:23 -0800
Subject: [*] Heritage 3.0.1
Heritage is a Macintosh shareware program for genealogy. Features of
the program include
* Data entry and retrieval of individuals and families
* Free form biographical information for individuals
Tom Grandine
[Archived as /info-mac/app/heritage-301.hqx; 695K]
Date: Wed, 20 Mar 1996 02:38:36 -0800
Subject: [*] HORIZON
Hello,
Find enclosed Horizon Demo, a BBC Micro emulator for the Mac. It's is
the sister emulator to Rainbow which is already on your infomac site.
I would appreciate it greatly if you could include this in your archives.
Sincerely,
Chris Lam.
http://www.aston.ac.uk/~lamcw/emulators.html
[Archived as /info-mac/app/horizon-10-demo.hqx; 213K]
Date: Wed, 20 Mar 1996 02:33:27 -0800
Subject: [*] HTML Markup 2.0 - the ultimate text to HTML experience
HTML Markup 2.0
The Complete Text-to-HTML Experience
by Scott J. Kleper
HTML Markup 2.0 is an "HTML processor". Unlike editors, it converts
existing files into web pages. Unlike converters, it allows you to
customize how the files look. This version has a TON of new features.
Some of my favorites are:
-The program is no longer linear and modeless. Instead of using Drag and
Drop, you can also
now run the program like a regular application.
-You can store multiple preferences in "sets" and select them from a menu
-You can select document colors (background, text, link, alink, and
vlink) from color wheels,
which is way cool.
-There are many more conversion options, like converting different styles
of lines,
converting file names into titles, and much more.
-Supports Macintosh Drag and Drop.
-More efficient - convert hundreds of files in seconds!
-Online balloon help and thorough documentation with tutorials.
-Swell new professionally-designed 3d-ish interface
If you have existing documents that you want to put on the web, HTML
Markup is the simplest and best way to do it. The program is PowerMac
native and also runs on 68k Macs. It's small, memory efficient, and very
very useful. If you register the program for US$20, you get even more
features like up to ten sets, inclusion of headers and footers, and more.
The latest version of HTML Markup is always available from:
Visit the HTML Markup homepage at:
Send your comments and suggestions to:
[Archived as /info-mac/text/html/html-markup-20.hqx; 547K]
Date: Wed, 20 Mar 1996 02:33:32 -0800
Subject: [*] HTML Viewer 1.2.1
HTML Viewer is a simple hypertext viewer, or "browser", meant to be
used by people who do not have access to a full-featured browser like
Mosaic or Netscape. It is also handy for authoring HTML documents, as
it does not have the overhead that the more capable browsers have.
New in version 1.2 is support for Forms and their corresponding CGIs.
This makes HTML Viewer a great tool for testing your CGIs without
having to set up a separate HTTP server. HTML Viewer will run
uncompiled and compiled AppleScripts as well as runnable AppleScript
applets. Also new are support for sounds files, and use of Internet
Config for handling network-based URLs.
[Archived as /info-mac/text/html/html-viewer-121.hqx; 309K]
Date: Wed, 20 Mar 1996 02:36:00 -0800
Subject: [*] Jon's Commands 1.5.1
This is a very minor update which simply fixes the "finder selection"
command. I changed compilers from the MPW c compiler to the new MPW sc
compiler. Apparently it changed the object layout in memory which caused
my hacks to cease working. So, I yanked the osax resource from 1.4 and
placed it in 1.5.1. I won't be upgrading this command any more, but at
least it will work.
Jon
[Archived as /info-mac/dev/osa/jons-commands-151.hqx; 272K]
Date: Wed, 20 Mar 1996 02:38:45 -0800
Subject: [*] Mac*Chat#106
Mac*Chat#105/07-Mar-96
Highlights Of This Issue
I announce the new Mac*Chat mirror site for Mac fans in
Australia, readers tell us about their favorite computer games that
don't involve killing things, we wind-up the discussion of
making color-t-shirts for your Mac, Frank Nagy defends DLT
tape-drives for backing-up a network, we hear
from several folks who have good information about the SCSI
cables connecting your Mac to your external drives and scanners,
we learn about System 7.5.3 from Apple and several Faithful
Readers, and we get several great ideas about printing big,
professional jobs on a network.
[Archived as /info-mac/per/chat/mac-chat-105-etx.txt; 30K]
Date: Wed, 20 Mar 1996 02:38:48 -0800
Mac*Chat#106/08-Mar-96
I uregently post the news about System 7.5.3 in this "bonus"
issue (since it got dropped somehow from yesterday's issue), we
hear where to download tax forms from the U.S. IRS, we hear about
some very interesting Mac-centric Web sites (and one extra just
for the heck of it), and Powerbook-owners get even more goodies.
[Archived as /info-mac/per/chat/mac-chat-106-etx.txt; 28K]
Date: Wed, 20 Mar 1996 02:36:54 -0800
Subject: [*] Mac-FTP-list-html Version 4.0.8
This is the latest {Mar 1,1996} version of the Mosaic/Newscape page for
accessing Bruce Grubb's list of ftp sites. It should replace the
previous version of mac-ftp-list-html.hqx.
This is the updated {Mar 1,1996} HTML version to Mike Gleason and Bruce
Grubb's Mac FTP list. It lists over 200 mac anonymous ftp sites (some
with notes), over 50 Mac web pages, and contains some instructions on how
to use anonymous ftp and find files as well a format chart showing which
programs decompress and decode which files. It requires HTML Browser such
as Lynx, Mosaic or NetScape and StuffIt Expander or equivalent
{unsitins.exe} to decompress.
Please note that this is actually four crosslinked files:
mac-ftp-list.html, ftp-list.html, www-section.html, and site-notes.html.
Please send newly discovered macintosh sites (with IP numbers and
directories to check if possible), bug fixes, and comments to:
[email protected] or [email protected]
Changes: Format chart updated; Conflict between text and html format
corrected; associate.com updated;
Added sites: ftp.cs.vu.nl; ftp.netbsd.org; puma.bevd.blacksburg.va.us;
ftp.unipd.it; http://www.carrier.co.at/res/mac/;
http://www.rockstar.com/ppp.html; http://www.tidbits.com/;
Defunct sites: wuarchive.wustl.edu (temporally); ftp.colorado.edu;
[Archived as /info-mac/comm/info/mac-ftp-list-408-html.hqx; 39K]
Date: Wed, 20 Mar 1996 02:38:39 -0800
Subject: [*] MacISAR
This is a French stack created with Hypercard 2.0 which is a relationnal
data base in anesthesia.
[Archived as /info-mac/app/mac-isar-fr.hqx; 557K]
Date: Wed, 20 Mar 1996 02:33:24 -0800
Subject: [*] Manual Maker 2.0
Manual Maker is a simple application that converts a collection of
SimpleText files into a low-overhead standalone document called a Manual
Reader. Besides displaying styled text and embedded pictures, a Manual
Reader provides chapter and section menus and a Find command. Manual Maker
is free for personal, nonprofit, and educational use, and Manual Reader
documents may also be distributed under those conditions. If you want to
distribute a Manual Reader document with a commercial or shareware product,
or if you just feel generous, please pay a $20 license fee. System 7 is
required for use of these programs.
Version 1.1 introduced a zoom box and fixed some minor display bugs.
Version 2.0 added a Print menu command, which uses AppleScript to tell
SimpleText to print a chapter.
-- James W. Walker
[Archived as /info-mac/text/manual-maker-11.hqx; 109K]
Date: Wed, 20 Mar 1996 02:33:41 -0800
Subject: [*] PrintUseMonitor 3.2
PrintUseMonitor monitors the pages printed on Quickdraw printers, including
all the StyleWriter series and LaserWriter 300 printer, and displays
a warning dialog when the print cartridge is about to run out.
PrintUseMonitor displays a progress bar indicating the Print Cartridge
wear and has many other features too.
If you refill ink cartridges then this application is useful for
determining when to do this, or if you always replace your ink cartridge,
this application can help you to determine when to order a new cartridge.
This version adds support for the Japanese language and the Color SW2200
printer. To use Japanese requires KanjiTalk. This program requires
System 7 to run.
Please include this on CD collections if you wish.
Best Regards,
Steve Smith
[Archived as /info-mac/prn/print-use-monitor-32.hqx; 38K]
Date: Wed, 20 Mar 1996 02:38:18 -0800
Subject: [*] Shakespeare Stack - Timon of Athens
Appended below is another in the Shakespeare Stack series of Macintosh
Hypercard 2.x presentations of the works of William Shakespeare ---
the play "Timon of Athens" --- free software under the GNU GPL --- a
binhex'd compact'd self-extracting archive. (Only three more to go!
"Measure for Measure" next, followed by "All's Well that Ends Well"
and then "Hamlet"....)
For anonymous ftp see "ftp.alumni.caltech.edu" under /pub/zimm, where
the entire Shakesperare Stack archive holdings are available, along
with other programs; or via URL
http://www.alumni.caltech.edu/~zimm
Best, ^z (Mark Zimmermann --- still seeking coins of 1852!)
[Archived as /info-mac/art/book/timon-of-athens-hc.hqx; 110K]
Date: Wed, 20 Mar 1996 02:34:18 -0800
Subject: [*] SingleNumber 1.1.6
Single Number is a puzzle game for one player, specifically, one
who is familiar with puzzle books or with the games found in the
puzzle pages of weekly magazines.
In this program, mac shows puzzles which the player solves.
Numbers (1-9) are given in several cells in the 9x9 matrix. Decide
the rest according to the following restrictions: "Each number (1-9)
should appear only once in the 9 cells of each vertical line, horizontal
line, and 3x3 matrix surrounded by the thicker boundary."
-Can preview puzzles both in "file open" and "book go to" dialogs.
-In addition to the "full" version, I prepared a "light" version for
those old macs like SE.
Thank you in advance.
Yoshimitsu Kanai
[Archived as /info-mac/game/single-number-116.hqx; 276K]
Date: Wed, 20 Mar 1996 02:36:48 -0800
Subject: [*] Smart Dubbing, Inline streaming GIF Web video
The program attached, Smart Dubbing, is a demo of a utility
to convert QuickTime movies to Animated GIF format.
As such, it is a Web utility.
Animated GIF enables Web Browsers like Netscape 2.0 to
present animating of moving pictures in Web pages without
plug-ins.
The demo is fully functional. The only thing different
>From the personalized version is that a message "Produced
by a demo" is displayed in the GIF.
The about text:
Smart Dubbing=81 is a software utility which enables small videoclips to
be played on a web page as they download. Smart Dubbing uses existing
animated GIF-technology to show inline movies.
Most important: this technique doesn't need special server software,
cgi-scripts, Hot Java, Macromedia plug-ins, helper applications and all
the stuff which makes it so complicated to put movement on a web page.
The software actually takes a QuickTime movie and compresses it into a
single GIF-file that can be recognised by Netscape 2.0.
Smart Dubbing's Home Page:
Smart Dubbing requires System 7 and QuickTime 2.0.
[Archived as /info-mac/comm/tcp/web/smart-dubbing.hqx; 139K]
Date: Wed, 20 Mar 1996 02:33:51 -0800
Subject: [*] SndSampler 2.7
SndSampler is a professional-quality sound recording and editing
application for the Mac. Its features are too many to list here in their
entirety, but following are a few to whet your appetite: 8 and 16-bit
sound, mono and stereo, sample rates up to 65 kHz, echo, two types of
reverb, chorus, flange, pitch bend, resampling, aiff support, can open
QuickTime movie soundtracks, can read audio directly off a CD, can import
.wav files, can extract 'snd ' resources from any file, can save 'snd '
resources to any file, direct-to-disk recording, can fix corrupted 'snd '
resources, and many more. Download today! Shareware fee of $12 registers
you for all versions 2.x.
SndSampler may be included on the info-mac CD.
[Archived as /info-mac/gst/snd/snd-sampler-27.hqx; 364K]
Date: Tue, 19 Mar 1996 17:04:30 -0600 (CST)
Subject: 6100s, DOS cards, and 7.5.3
Folks,
Here it is, straight from Apple. If you use the DOS card on a PowerMac
6100 and have just installed 7.5.3, you'll discover your Windows (sic) CD
ROM disks are unaccessible.
I fought this problem for nearly a day in our lab. I called Apple four
times, and after about mid-afternoon, I found an Apple phone techie who
knew how to navigate and do some research for me. After several minutes
on hold, he returned and told me to trash the NEW 7.5.3 version of the CD
ROM driver (whatever version number that is) and replace it with the
previous version, 5.0.4.
He stayed on the phone with me until I restored 5.0.4 and appeared just
as happy as I was that the Windows (sic) disks were now recognizable.
Apparently, this is a new discovery.
I'm disturbed that something like this was not discovered during testing,
but at least the DOS card and 7.5.3 are working.
--Larry
Date: Tue, 19 Mar 1996 16:18:56 -0500 (EST)
Subject: 7.5.2 Update Comments
> The 7.5.2 update can install a new copy of MacTCP 2.0.6 on some systems.
> It did this on my Performa 635. Please save all of your ip settings
> before running this package.
Let's clear up a bit the confusion produced by the diseased mind at
Apple who chose the current version numbering scheme:
System 7.5 = System 7.5
System 7.5.1 = System 7.5 + System Update 1.0
System 7.5.2 = System 7.5.2
System 7.5.3 = System 7.5 (or 7.5.1 or 7.5.2) + System Update 2.0
1. System 7.5.2 is essentially System 7.5.1 re-engineered to support PCI
Macs. There is no upgrade path from 7.5 or 7.5.1 to 7.5.2; non-PCI Macs
(excepting some PowerBooks) cannot use 7.5.2; PCI Macs cannot boot off
7.5 or 7.5.1.
2. System Update 2.0 is known at Apple also as System Update 5.0 (the
first three are the updates for system 7.1).
> I was one of the lucky individuals who downloaded the update files From
> Netscape's ftp server. All of those files arrived with strange or
> missing Type and Creator information.
That's because they had not been stored on the Netscape site in
MacBinary, I think.
Florin Neumann
[email protected]
Date: Wed, 20 Mar 1996 16:48:42 +0500
Subject: [A] Deleting files by single keypress and Finder not showing full
filenames
>Though I am not a Mac addict (I feel perfectly at ease with "IBM compatibles"
>and DOS/Windows), I certainly appreciate MacOS' GUI, but I have a couple of
>questions about the Finder:
>1) Wouldn't it be much easier to be able to DELETE any file by simply pressing
> a key? (eg ). Does anybody know of an extension, init, patch, add-on,
> that can achieve this? (of course, leaving me the chance of backstepping in
> case I press accidentally...)
This is an UNimplemented feature of System 7.5.3. There is an extension
called "Finder Extension Enabler" that should be in the 'gui' directory
that will allow you to enable this feature.
>2) I HATE not being able to see the complete name of files unless I press
> -I. Since files can have names up to 32 characters (or 31?), why
> isn't the finder showing me the *whole* name? I firmly WANT that! Again,
> anybody out there has anything at hand to force the Finder into showing
> file names in full?
This is an implemented feature of System 7.5.3. When you can finally get
the upgrade, enjoy seeing your full filenames.
Doug
[email protected]
Date: Wed, 20 Mar 1996 00:39:21 -0800 (PST)
Subject: [A] Where to find info about MS ClipArt Gallery problems
In IMD v14 #65, Lyman Green ([email protected]) asked about MS
ClipArt Gallery objects showing up as blank boxes inside PowerPoint
presentations. He may find the answer in Microsoft's Knowlege Base; they
list several bugs, fixes, and patches available on this specific topic.
He should point his browser to:
http://www.microsoft.com/kb
...then choose PowerPoint as the product, and enter the search terms
"macintosh clipart gallery".
Hope this helps,
Andrew
P.S. If Apple's server seems inaccessible during business hours, try
getting up at 3 or 4 AM and downloading System Update 7.5.2. Hey folks,
at least they're making it available for free!
Date: Tue, 19 Mar 1996 16:19:53 -0500 (EST)
Subject: [C] First impressions on 7.5.3
> - translucent dragging doesn't seem to work; when I drag an icon, I
> still get only its outline.
According to the read me files, translucent dragging works only on PowerMacs.
Florin Neumann
[email protected]
Date: Wed, 20 Mar 1996 11:25:02 -0500
Subject: [Q] How fast is a Performa 6300?
Hi everyone-
I haven't seen it included in any benchmark tests, and I'd like to=
recommend a Performa 6300 to a friend. How fast is a 6300 compared with,=
say, a PM 7500/100 or a PM 7200/90? Will it run SoftWindoze at an=
'acceptable' speed? (I consider SW2.0 on my PM7500 to be acceptable, for co=
mparison)
Would anyone out there recommend a different machine for a roughly=
equivalent price? My friend is a tech-bozo, has never even sat down in=
front of a Mac, and has no software (so the bundled sw, CD's and modem's=
important). Mainly he wants it for general home use; not likely to need=
much in the way of expansion slots. Should we just wait for a speed-bumped=
PM 7200/120?
TIA,
Marty Lindower
[email protected]
Date: Wed, 20 Mar 1996 16:50:41 -0500
Subject: [Q] Netscape -> Resource fork errors?
Hi everyone-
Every time I run Netscape (this happened with v1.1 and still occurs with 2.0)
on
my PowerBook 160 10/320, Norton Utilities later finds this error:
Scan Catalog
An error was found in a file record in the catalog b-tree.
The resource fork for the file, "Netscape Preferences", has an incorrect
physical length. (node 1044, record 2) (5,6,16)
Node #1044, Record Offset 2
The leaf file record was fixed.
The error gets fixed and stays that way until the next time I run Netscape. I
get no other disk errors at all.
Does anyone know what causes this, and is there a cure?
TIA,
Marty Lindower
[email protected]
http://www.pcnet.com/~martyl/
Date: Wed, 20 Mar 1996 15:23:48 CST
Subject: [SUMMARY] Performa won't boot - another battery problem; worse???
Thanks to the following for replying to my question about my Performa
and a possible dead battery:
"Beth C. Gladen"
"John D. Zahari"
"Ray Swartz"
"Scott L. Horton"
"Ying Wang\\"
Bill Campbell
[email protected]
Jon Page
Michael Blasco
[email protected] (Ong Cheow Seng)
[email protected] (F. Neumann)
[email protected] (John S. Reynolds)
The core of my original question:
> When the Performa is turned on, the chimes sound out clearly, and the
> hard-drive starts clicking as usual. However, it stops a few seconds
> later. There is no happy, sad, or any other Mac face on the screen.
> Just a blank screen. I also couldn't boot with a floppy.
Many folks suggested getting a new battery, since there seems to be a
rash of Performas and similar models having dead batteries at this
point in their life.
There isn't a large Mac dealer here, so I ordered a battery from a
local radio supply dealer. The day before I went in, someone else had
ordered the very same battery!
Anyway, after a few days I got the battery, installed it, and turned
on the Mac. I heard the same clicking of the hard-drive, then
silence, and I thought the worst, but then the startup screen popped
up on the monitor, and things were great. The battery was only about
$9 (U.S.).
A further question: In addition to resetting the date/time, I had
other control panel settings to change (32-bit addressing, choosing
printer, etc.). I don't remember all my previous settings. Are there
any in particular to check? Should I use TechTool to save my PRAM
settings for future reference?
Thanks again,
Michael Cook
[email protected]
These are not the opinions of my employer.
More battery info:
I'd bet it's the battery. The battery is part no. 742-0011. You can get
it from any Apple authorized service centre (it's about $10), probably
in other places as well.
It appears that many LC475 (= Performa 475 = Quadra 605) were shipped
by Apple with poor quality lithium batteries. Consequently those
batteries, which should last for 4-5 years, are expiring after
less than 2 years. The lithium battery powers the parameter RAM
(PRAM), and its failure on an LC 475 will cause all sorts of strange
symptoms, among which "dead" video, hard disk problems, etc (some of
them were reported on info-mac, see the "Solutions for dead video in
Performa 475" thread in the January 1996 issues). Many dishonest
and/or poorly informed technicians will tell you variously that you
need to replace the video board/chip, that the hard drive is suffering
>From stiction and needs to be replaced, etc.
If you have serious problems with your LC 475, by all means get a
professional opinion. But before spending big bucks, make sure the
problem isn't a failing battery.
You can try zapping the PRAM upon restarting (press the CMD-OPT-P-R
keys during restart); if the problem goes away but comes back upon
subsequent restarts this might indicate there's battery problem, but
it won't work in all circumstances. The best test is to replace the
battery. It's part number 742-0011, it costs about US$10, and you can
purchase it from any authorized Apple service provider. (It looks like
an AA battery used in walkman tape players, but the AA is twice as
long.) To replace it simply open the LC chassis (the lid is held in
place by a screw at the back and by two clips), pop out gently the
old battery from its socket on the motherboard, and pop in the new
one. Make sure to take the usual precautions (ground yourself and the
Mac, and don't touch any parts on the motherboard, particularly any
chips); also make sure you match the polarity.
Florin Neumann
[email protected]
Date: Tue, 19 Mar 96 11:10:35 EST
Subject: ARA question
I'm having a problem using ARA (Apple Remote Access). I bought the
ARA Client 2.0.1 for Mac from the computer store. I have a PowerMac
7100/66 running System 7.5.1. I have MacTCP version 2.0.6, Network v.
3.0.2, and AppleShare 3.5 all installed. I have a Supra 14.4 fax-modem
with which I'm able to use telnet and Netscape etc.
I'm able to log on using ARA Client and connect. In the Chooser I can
see CMU's Mac zones and can select one and see the different Macs in the
zone. However, when I try to mount one, it says there was a problem
calling an AppleShare routine, there is a problem with an AppleShare
driver - re-install AppleShare. Do I need another driver? I should
mention that I also have NetWare UAM v. 3.00 in my AppleShare folder.
--Pete
([email protected])
WWW: http://www.cs.cmu.edu/~pshell
Date: Tue, 19 Mar 1996 12:00:06 -0600
Subject: At Ease with System 7.5.3 (Update 2.0)
I recently installed the System 7.5 Update 2.0 on a Mac IIcx that had At
Ease 2.0 on it. It now refuses to boot with At Ease installed. I
upgraded to At Ease 3.0 and it still hangs! Is there an incompatibility
with 7.5.3?, and what is the definitive version of At Ease since I see
reference to at least 3 of them.
Regards,
Ken Fox
[email protected]
Date: Wed, 20 Mar 1996 03:50:17 -0500
Subject: base64 encoding: how decode?
Recently a new eWorld user has sent me two messages that included some
non-ASCII text encoded using something called base64. BinHex can't make
heads or tails of it, nor have I been able to locate a base64 decoder
using the primitive software-acquiring methods available to me. (I can
obtain software from Info-Mac mirrors and UM via e-mail but don't have
web or ftp access.) I've recently learned that eWorld will be defunct
shortly, and the user who sent me the files knows nothing about decoding.
Can anyone help me obtain the necessary decoder? I reproduce below the
headers of the second decoded message with some [comments]. Thanks much!
--PART.BOUNDARY.0.19190.hp1.online.apple.com.825548181-ad [other msg. had
Content-ID: different #s]
Content-type: application/applefile;
name="Archive.sit"; [my friend's internal file name]
X-Mac-Creator="53495421"; [the other msg. had a different #]
X-Mac-Type="53495444" [the other msg. had a different #]
Content-Transfer-Encoding: base64
[several encoded lines here]
Content-ID:
Content-type: application/octet-stream;
name="Archive.sit";
[many encoded lines here]
Carol Conti-Entin Internet: [email protected] N.E. Ohio, USA
Date: Wed, 20 Mar 1996 07:00:59 -0500
Subject: CH Flightstick Pro and Marathon #1
Can someone please help me with step by step instructions (something that
even I can understand) in configuring the Flightstick pro for the first
Marathon. The CH manual is like reading a different language to me! I
realize that the rest of the world is probably not waiting anxiously for
this info, but it would sure help me. Thanks, John Popowitz
Date: Tue, 19 Mar 1996 14:54:36 -0800
Subject: Clobbered BTress ANSWER
Thanks to everybody for their encouragement and thoughtful responses. The
gist of the answer to *why does my Powerwave generate such a high rate of
disc corruption errors* appears to be:
The machine came with a Quantum Fireball internal hard drive, which ships
>From Power with its disc write cache enabled. At shutdown, the machine
flushes the MacOS caches and cuts power before the hard drive can flush the
drive disc cache, leaving said drive corrupt, or at least confused.
The interim solution was to disable the disc write cache with FWB Hard Disc
Toolkit. This was not wholly successful, as a speed hit resulted, but the
BTree errors went away.
I also sought help from PowerComputing, but after a couple of weeks of
non-response, their tech told me via email that I was powering up the CPU
with the external drive off, which, with my particular configuration, can't
happen.
Next, Guy Kawasaki wrote that Apple and APS were looking into the problem,
so I called APS. Fortunately, I had purchased an external drive form them a
couple of years ago, and to my surprise, I must have filled out a warranty
card. A nice APS lady says they have updated APS PowerTools with a patch
that gives the ingternal drive time to flush its cache at shutdown, without
requiring that the disc write cache be disabled. She's sending the upgrade
to me and I should get it by the end of the week. (She's in Kansas City and
I'm in California). I will have to reformat to change from FWB to APS
drivers, but to be freee of the dreaded BTree corruption will be worth it.
If it works.
Again, thanks to all who helped.
Date: Wed, 20 Mar 1996 14:42:03 -0500
Subject: Database of Info-Mac messages
For several years I have been maintaining a database of the messages on the
Info-Mac list for people at the University of Michigan. It is more or less
complete back to Volume 3 Issue 50 in October 85 and contains 86234
individual messages occupying over 100 megabytes at the moment. The
machine it is stored on is scheduled to be shut down this summer and I will
no longer have any place to keep it. If anyone is interested in having
this, I would be glad to give it to them. Unfortunately it is in the form
of a Spires database and I doubt if many people will be able to cope with
such a thing. Let me know if you're interested.
Here's a sample message from 10 years ago today, when the MacPlus and
AppleTalk were new and people were just trying to figure out what AppleTalk
was good for. Mr. Teague was right, this string is still in the system
file today and is the owner's name from the Sharing Setup control panel.
Msg-Date: Thur. March 20, 1986 (Record 1371)
Subject: AppleTalk node name routine
Following Walter Smith's suggestion, I found the AppleTalk node name as a
string resource in the system. It turns out that it belongs to .MPP rather
than to Chooser, so it may be intended for more general use than just
printer status messages. The following routine (written for Megamax C)
returns the node name in a user-supplied text buffer. It works under System
3.1.1 and Finder 5.2. I haven't tried it under earlier versions yet, but
the name should be returned as an empty string if the handle comes back zero.
Calvin Teague
Code: Select all
(Source: ARPA.INFO-MAC, Volume 4, Issue 37, Fri. March 21, 1986).
Mike Alexander Internet: [email protected]
University of Michigan AOL: MAlexander
+1-313-663-1759 Fax: +1-313-663-0158
Date: Tue, 19 Mar 1996 16:20:51 -0500 (EST)
Subject: Deleting files by single keypress
> pressing a key? (eg ). Does anybody know of an extension, init,
> patch, add-on, that can achieve this? (of course, leaving me the chance
> of backstepping in case I press accidentally...)
You can use a macro utility (e.g. QuicKeys) to program a macro that will
move the selected file to the Trash. Or you can install Nevin Liber's
Finder Extensions Enabler 1.1.0 or Marc Bizer's Secret Finder Features
in System 7.5.3 to enable the comand-delete keyboard combination.
> file names in full?
You're not the only one. Apple has -- after many customer requests -- finally
enlarged the filename column in System 7.5.3's Finder. Alternatively, you can
use one of a set of custom Finder prefs available on Info-Mac.
Florin Neumann
[email protected]
Date: Tue, 19 Mar 1996 22:51:38 -0400
Subject: Deleting files by single keypress and Finder not showing full
filenames
hi Adriano!
Try "OpenWide" and "Finder Delete Enabler Key". They should be available
>From Info-Mac and AMUG.
I hope this helps!
Mustafa Ziyalan
[email protected]
http://maxwell.njit.edu/merhaba/dir/mziyalan/
Date: 20 Mar 1996 00:07:30 GMT
Subject: DO NOT BUY MEGAHERTZ PC MODEM FOR MAC!!
I have been the miserable owner of a 28.8 Megahertz CruiseCard since a
few months ago. ON NO ACCOUNT SHOULD ONE BUY THIS MODEM! I have had
great difficulty faxing with it, and NO SUPPORT at all has been
forthcoming from Megahertz.
The problem is that the modem fails to connect with about 20% of fax
machines. It dials, handshakes, but does not send. When I try the same
experiment with either of 2 other modems (Global Village or Magnum) on
the same phone line and to the same fax machines, it works fine! The
failure is 100% repeatable in my experience.
Megahertz has an e-mail address for tech support. I have used this at
least twenty times, and NEVER HAD A REPLY FROM TECH SUPPORT! It is
abundantly clear that messages posted to [email protected] are
infrequently, if ever, replied to. The last time I tried was in January,
when out of exasperation I sent the same message 10 times!! No reply.
I have spent hours on the phone with Megahertz, often at my expense, to
diagnose this problem, but they are unable to say with certainty what is
wrong. Part of the problem is that their hardware is made for PC, and
their support for Mac is awful. For instance, if you have a PC and the
ROM of the modem needs to be flashed, this can be done at once via their
BBS. They do not offer this service for Mac, but offer instead to
exchange your modem by DHL. Cost for this service: $35!! And if it does
not work, too bad, since it is not refundable! You, the user, pick up
the tab for what would otherwise be unnecessary if Megahertz supported
Mac equivalently to PCs.
This is a poor product, with miserable support for Mac users. I CANNOT
ADVISE STRONGLY ENOUGH THAT YOU DO NOT BUY A MEGAHERTZ MODEM FOR
MACINTOSH! I would be very interested to know if other users out there
have this SAME problem (no general problems, please), since I am
contemplating legal action under the British Columbia Sale of Goods Act
against Megahertz.
Amir Attaran
[email protected]
Date: 19 Mar 1996 11:52:23 -0500
Subject: EasyView and Carpe.Diem (Q)
Greetings,
If you've gotten EasyView to digest the Carpe.Diem digest I'd like to know
how.
TIA
Peter Jorgensen
This message comes via PowerTalk and a StarNine SMTP gateway.
Date: Wed, 20 Mar 1996 23:28:19 +1100
Subject: Eudora's JH Icon (was: Eudora ack)
>[email protected] (Bill Stanford) wrote:
>>> (why does Steve Dorner use the initials "JH" to stand for signature?
>>>does anyone know?
>>> his SO for instance?;-)
>I think that the JH in Eudora is to apply your *John Hancock* to the
>message as in the famous signature (at least to us U.S. type users anyway
Sigh... having an American mom just wasn't enough... I missed on this one.
But I'm glad to know, since like many here I sit staring at Ms Welty
many hours a week, and while the question wasn't driving me crazy...
I _would_ like to thank Louis Mackey here, and Ethan Benatan, christopher
jones, Darrell Greenwood (for "Put your 'John Henry' here sir!"), Edward
Floden, R Shapiro, and a couple of others whose posts got lost... And Gib
Henry whose own question I haven't gotten to answer yet... And Paul
Blumstein who thought Steve Dorner might be Australian; though Paul, I
think you were thinking of Anarchie's Peter Lewis, the other genius...
Many thanks, as usual the Digests proves a wonderful place to ask a
question, even something trivial! And now to put my short "jh" on this one
with an easier mind... :-)
--Bill Stanford||[email protected]
"Men build scales, but the Gods blow upon the lighter pan"--(Wolfe)
Date: Tue, 19 Mar 96 18:19:31 -0600
Subject: Face Folder Icon, how?.....
>I have some photographs of a few of my friends faces and I wish to create
>some custom folder icons of their faces - no background or frame.......
>How can one do this ?.....
>To date I have tried Photoshop to delete the background which is fine and
>then Folder Icon Maker to create the icon - but there is still the
>photographs frame/outline left.....
So, I assume that what you are doing is letting Photoshop give the
original a custom icon, then you're dragging that file onto Folder Icon
Maker.
Photoshop puts a black border around the custom icon automatically, for
your convenience, to serve you better, etc. I imagine this border is
intended to indicate to you the shape of the image.
Try this:
In Photoshop, select only that part which you want to "iconize".
Select "Edit -> Copy"
Go to the Finder.
Select a folder and Get Info.
Tab to the icon box and select "Edit -> Paste".
If your image has a white or transparent background, you'll get an icon
without a background or a frame.
If what you want is a folder icon with this frameless icon inset on it,
then drag the thing you just icon-ized onto Folder Icon Maker.
Voila.
chazl
03.19.96
Date: Tue, 19 Mar 1996 21:08:27 +0000
Subject: GV-faxsoftware v2.5.3 & M$ Word 5.1a
[email protected] (Marcel Aussendorf) wrote:
>I found a problem with M$ Word and GV fax-software (v2.5.3) that I wasnt
>able to solve with the GV-techsupport team. The fax-shortcut doesn't work.
The same problem exists when using the shortcut with FaxSTF. You need
to have
- the operating system
- the application
- the fax program
all three in the SAME language version (for example, all in English, or
all in Dutch...).
I think the GV software behaves similarly.
Best wishes, Christian.
[email protected] -- http://www.access.ch/mus/members/cbuser/cbuser.html
Date: Wed, 20 Mar 1996 23:28:14 +1100
In Info-Mac Digest V 14, #62, [email protected] (Marcel
>Holding down the option-key when selecting the Print-command from the
>file-menu should change the name 'Print...' in 'Fax...' thereby preventing
>to open the chooser. However, this doesn't work.
>What can be the cause of this problem? Has anyone experienced it before?
>Can anything be done about it?
[snip]
>Software:
>System 7.5.1
>Global Village software v2.5.3
Marcel, the cause of the problem will be Word's non-standard implementation
of menus--one of the reasons, not the only one of course;-) --why Mac users
instinctively dislike Microsoft...
I think your fix is to upgrade to GV Teleport 2.5.5 or 2.5.6, as 2.5.5
fixed quite a few incompatibilities. With either of these versions of
Teleport, Word 5.1a's Print selection changing by hot key to Fax works
nicely for me with a very similar setup on a 540c.
You can get the 2.5.5 and 2.5.6 updates at
The 2.5.6, though mostly for PPC Macs, is faster to get since the 2.5.5
update includes the flash ROM upgrade to v.1.2--which if you bought your
Platinum after about June last year you don't need to do...
hope this helps...
Date: Tue, 19 Mar 1996 09:02:55 -0800
Subject: info-mac wais database off the air for up to a month
Hi All,
The info-mac WAIS database (and other mac and graphics databases @
http://hornet.mmg.uci.edu/cgi-bin/nph-fwais.pl
that I started and have maintained sporadically since shortly (?) after
Thinking Machines dropped it), is going off the air shortly, probably
within a week or two and will probably be off the air for at least 2 weeks
while I move self, machines, and assorted detritus to a nother location.
When it comes back, I'll post again.
In the meantime there is at least one other such archive:
[email protected] (Tim Tuck) maintains an overlapping set of wais
sources:
"You can check it out at I have a WWW to WAIS
gateway running on it so you don't need a WAIS client to access it although
you can use MacWais or WaisStation if you like :)
If you use a WAIS client the sources are:
infomac
tidbits
machttp
firewalls
bugtraq
Server is wais.sensei.com.au, PORT 210"
As well as the ususal commercial search engines that explode in your face
every time you use a Web browser.
Cheers
Harry
Harry J Mangalam, Microbiology and Molecular Genetics, College of Medicine,
UC Irvine, Irvine, CA, 92717, (714) 824-4824, fax (714) 824 8598,
http://hornet.mmg.uci.edu/~hjm/hjm.html
Computational Biology..Silicon Graphics..Woodworking..Bicycling..Linux..WWW
Date: Wed, 20 Mar 1996 01:22:52 +0100
Subject: Looking for a utility
Dear Kirk,
I can give 3 suggestions for hiding open app's:
1. clicking just outside the active window when holding down the option-key
will hide the app of this window (as far as I know an undocumented feature)
2. When possible use Apple's Control Strip: a module called 'Process
Manager' (part of the ES 1.2 Package) will show the icons of all open
app's, including the Finder. You can activate these by clicking on them,
drop files on them, quit the app's directly, find them on disk etc. Most
important: holding the shift-key when clicking on an icon will activate the
app and hide others.
3. Use an macro-engine: Keyquencer. Takes very little ram (about 80k), and
performs this task efficiently.
Marcel Aussendorf
Katholieke Universiteit Nijmegen
Date: Wed, 20 Mar 1996 08:57:45 -0500
Subject: MO Drive for PB5300 - Myth!
All I know is what I see in MacWeek.
Fujitsu has a full page ad for their internal Magneto Optical drive
for the PB 5300 or 190. They list the phone number 800 898 1455 if
you want more information. It would seem pretty slimy (but not
unheard of) for them to have such an advertisement if the product was
still six months off.
Their web page has little information, but this page
(http://www.fujitsu.com:80/FCPA/service.htm) has some additional phone
numbers, including some non 800 numbers for our international friends.
Good luck,
--Jim Dempsey--
[email protected]
http://frontdoor.bbn.com/users/jjd
Date: Wed, 20 Mar 96 12:52:13 EST
Subject: Phantom file
Can someone help? I have a zero K file on my hard drive, created by (I really
am not sure). It is called "Temp SD Copy File." When I try to Trash it, my
Mac says that the file is locked. It won't let me trash it, nor
rename it. The file is NOT locked. When I go to "get info" on the file, the
locked
box is empty. I can't drag the file to the Trash. I have tried holding down
the option key to force emptying the trash with no luck. ResEdit says
there is a file lock error (-45) on this file, and I cannot open the file with
ResEdit, which further says there is no resource fork in this file, of course.
Can anyone give me any pointers on how to eliminate this pesky file from my
hard
disk?
Thanks in advance. Dennis Perzanowski.
Date: Wed, 20 Mar 1996 10:04:58 -0500
Subject: Power Computing
On 3/19/96 at 9:26 AM, The Info-Mac Moderators wrote:
>Date: Fri, 15 Mar 1996 16:23:28 -0400
>From: "Mary, Greg and Becca Lamping"
>Does anyone in this group have any experience with Power Computing
>products? A friend is in the market for a new computer and is
>considering a Macintosh Clone. Any comments would be helpful.
>Greg
>[email protected]
I have a 604/120, and couldn't be happier. At work I have a (Apple-brand)
8100/100AV, and, except for the AV option and the speed difference, neither
I nor my software can tell the difference between them.
Fortunately I haven't needed tech support on it yet, but I hear they
respond a heck of a lot better than Apple typically does.
Also, I understand P.C. just lowered their prices, so they're a great deal,
as well.
HTH,
Randall B Meadows * Software Engineer and Bug-Finder Extraordinaire :)
FGM, Inc. * 131 Elden Street, Suite 308 * Herndon, VA 22070
email: [email protected] * Voice: (703) 478-9881 * Fax: -9883
Date: Wed, 20 Mar 1996 17:01:41 -0500 (EST)
Subject: Problem With Zip Drive and Nikon Scanner
I have a problem involving a scsi zip drive and a Nikon Scantouch
Scanner. I'm trying to collect as much information as I can
before I make things worse than I have already. Essentially, the
scanner was working fine until I installed the zip drive
software. I then did the best I could to remove all the zip
software and the scanner still doesn't work. Details follow.
I will greatly appreciate any advice either to the list or directly to me
[email protected].
Sorry this is so long but I've been as complete as I can be.
We have a Macintosh Performa Power Mac 6115cd. We are still
running OS 7.5. We have a Nikon Scantouch scanner connected to
the scsi port. It has been working OK. (Graphics are scanned by a
Photoshop Plug In. We've been using Omniscan for text scanning.)
We have been running Ram doubler. We have little else that is
really unusual.
We bought a zip drive. I connected the hardware. I left the
scanner alone at scsi 6 and terminated. That has been working
fine. I set the zip to scsi 5 (the only other choice) and not
terminated. I checked things out. The scanner still worked.
Then I installed the zip software. Omniscan still works. But the
scan with the photoshop plug in produces the error message
"application unknown has unexpectedly quit because an error of
type 1 occurred."
I disconnected the zip drive and removed files (extensions,
control panels, programs) installed by zip. I went so far as to
search the hard drive by date. The problem continues. I can re-
install the system from a cd so I tried that. The problem
continues. It seems that I should be able to get back to where I
was and I can't.
Oh yeah, by changing the scanner to other addresses, I can sometimes make the
system hang instead of having the program bomb.
Date: Wed, 20 Mar 1996 15:40:44 +0000
Subject: Speed Access 1.1.2 still crashes the system
Speed Access 1.1.2 still crashes the system when Speed Copy is used to
empty the Trash. This problem has been reported all along and is still
present. Use with extreme caution.
I know that this is the problem component, because of testing performed
with and without it.
I am using a Power Mac 6100 under System 7.5.3
Stephen C. Camidge
[email protected]
RR #1, Desboro, Ontario N0H 1K0 Canada (519) 363-3912
Date: Tue, 19 Mar 1996 18:02:43 +0100
Subject: Stufft Browser ?
All,
I use Stuffit to archive all my software. I find it handy and I've neve had
any problems with it. Now I am looking for aa utility or extension that
will allow me to get into the archives quicker. I don't want to unstuff
everything or open StuffIt every time I just want to have a quick peak.
Now I've heard something about an INIT called StuffIt Browser, but hav
ebeen unable to find it in the usual places. Can someone help, send it to
me, or suggest an alternative ?
Any help would be appreciated.
Thanks
Hanns [email protected]
Date: Tue, 19 Mar 96 16:56:25 EST
Subject: Sys 7.5.3 (One more C)
It has been a heckuva day. Leslye's mother was to be released from the
hospital, she could not return to her "assisted living" center apt, and
the nursing home that yesterday said they had a bed today did not have
one. It has been a real roller coaster ride. Fortunately(?) someone in
the hospital's "extended care" facility died this afternoon, so Mrs Ruth
can stay there until there is a nursing home opening. What a ride.
It was a blessing to get mail re my sub-enthusiastic comment on the 7.5.3
update. I needed those laughs. I was particularly convulsed by the chap
who suggested that I burn a CD-ROM with 7.5.3(U) and put Norton on the
disc. Gawd, that's funny! Superior solution, yes? And I also got a grin
out of the guy who asked if I had bothered to read the README files that
accompanied the update. As one of my masters said, "Al isn't any smarter
than the rest of us. He just reads the manuals."
No, 7.5.3(U) isn't a system. It's the kitchen sink. And it is not for
anyone on a budget. Thanks, Apple, but I think I'll keep my three-each
copies of Norton, MacTools, and SAM on floppy for our various critters.
And I'll do an "easy" install of 7.5.3 on our critters. And trash Speech
Manager and Macintalk afterwards.
Again, thanks to those super loyalists who didn't approve of my negative
comments of the other day. I needed those chuckles today.
Al Bloom
[Gee Al... it does look like they had a point with the MacTCP stuff; it
was invisible for a reason... -Gordon :-) ]
Date: Tue, 19 Mar 96 18:13:12 EST
Subject: System 7.5.3 & SAM (A)
On Mon, 18 Mar, Dennis L. Galway wrote
>I recently updated my system to 7.5.3 using the system updater. When I
>restarted my system SAM intercept Indicated a problem with virus
>definitions. The dialogue box indicated that the definitions wre not
>in the system folder or invalid. I've downloaded and installed the
>latest definitions and reinstalled SAM. However, it still doesn't run.
>SAM intercept will not load and if I try to use SAM I will be informed
>that the virus definitions are invalid.
Dennis, I first saw that with SAM 4-point-naught when we got 7200's. I
dropped a note to Symantec and got a 4.0.7 update a couple weeks later.
Things are easier now -- all of a month later. Hie thee to Symantec's
ftp site (ftp.symantec.com) and get the 4.0.8 updater.
Al Bloom
Date: Tue, 19 Mar 1996 12:33:07 -0500
Subject: System 7.5.3 (C)
At 14 Mar 96 20:59:33, Allan M. Bloom wrote:
>I did the "universal" install today. It was depressing. I didn't get a
>system that'd work on any Mac. I got a System file and an enabler that
>worked with Macs that could handle 7.5.1 and another enabler that worked
>with Macs that need 7.5.2 and a whole bunch of other useless stuff that
>pretty much took over the free space on my HD.
OK, I'm getting a bit tired of the whining. I installed a virgin universal
7.5, applied the universial update to it, burned a CD, and I can now boot
an 8500, 7500, and a couple Performas. It DOES work, but you have to break
down an read the information that came with the release.
>Want a thrill? System 7.5.3 with wonderful new Open Transport 1.1 will
>still not run Eudora Light (1.5.4). Nor will it run LaserBridge. And if
>you wipe OT's internet stuff, you cannot install MacTCP. Seems there is
>an invisible file with that name in Control Panels. A document. With no
>owner to speak of. Same game with Network. I had to go into my handy
>dandy old Central Point "FileEdit" to see and wipe those two files. How
>many of y'all can do that?
If you hadn't messed with things, you could use the "Network Selector"
Utility Apple graciously created to switch between OT and MacTCP.
>What I really wanted from this exercise was a System Tools floppy that
>would boot any Mac I "own." Who ruddy cares what boots a particular Mac
>>From its internal HD? Not a prayer, children. I haven't seen the 7.5.3
>CD-ROM yet, but I don't expect anything more useful than what I've seen
>so far.
Creating a floppy WILL be a problem, but mainly due to the size. My boot CD
with Norton and SAM works like a charm, thank you.
Apple screws up lots of things, but 7.5.3 doesn't look like one of them.
Sure, not everyone can get the update immediately, but broke down and paid
$4 to download from AOL and got it in 1 1/2 hours.
Be patient, read the instructions, get rid of the funky inits, and things
will be fine.
Date: Tue, 19 Mar 1996 13:20:49 EST
>And if you wipe OT's internet stuff, you cannot install MacTCP. Seems
>there is an invisible file with that name in Control Panels. A document.
>With no owner to speak of. Same game with Network. I had to go into my
>handy dandy old Central Point "FileEdit" to see and wipe those two
>files. How many of y'all can do that?
Actually, there is a program called "Network Software Selector" that
handles switching between Open Transport and "Classic" networking (i.e.,
MacTCP and Appletalk). It's installed in the "Apple extras" folder. This
is documented in the file "Installing this update", and was also
mentioned in Tidbits.
By default, the System Update 2.0 installer installs OT but leaves
"classic" Appletalk selected unless OT was previously installed. At
least that's what happened for me, using an easy install.
For a custom install of a universal system, Open Transport is
selected instead, which is not unreasonable, since some Macs cannot use
"classic" Appletalk.
The "useless stuff" is probably for other varieties of Macintosh
computers. This is a "universal" update, after all.
Try the System 7.5 Disk Tools disk.
> Who ruddy cares what boots a particular Mac from its internal HD?
Universal systems are of little use on an internal HD. After all, how
often does one swap internal hard disks ? They are really for ZIP disks
and other high capacity removable media which really can be moved around
between different machines
Shih Tung
Chem E
Best l'il Tech School
on the Charles
Date: Tue, 19 Mar 1996 14:43:24 -0600
Allan, you're being silly here:
Do you mean to say that you can't boot this disk on any machine, or only
that you don't like the strategy of two enablers? If the latter, why? Do
you also complain about the fact that the Finder and the System are two
different files? Who cares how Apple stores their system software so long
as they don't give you hundreds of little files cluttering up your space?
That should work just fine. I don't know what the problem is that you're
running into.
>And if you wipe OT's internet stuff, you cannot install MacTCP. Seems there is
Did you even bother reading the README files that came with 7.5.3? The
specifically tell you about this and the Network Switcher software. If you
had, you would not have gone through all of this pain.
pr
Pete Resnick
QUALCOMM Incorporated
Date: Tue, 19 Mar 1996 22:05:36 -0500
Works fine for me. 7100/80. I didn't even do a clean install, but my system
is only a couple weeks old, so I haven't had a lot of time to collect
problems. I did back up before running the update.
That's certainly the party line, though I do vaguely remember one
dissenting post somewhere. Something about a trick to get it to work. Since
I don't have a laser printer at home, I didn't pay enough attention. Sorry.
>After flushing the "MacTCP" document from Control Panels, I could install
>the real MacTCP CP and get Eudora working again. I suspect I'll have the
>same luck with the "Network" document and get LaserBridge working again
>after installing NSI 1.5.1 (Easy install first, then custom install the
>bridge).
Apple gets a few demerits on this one, but most of the info is in the "New
in this Update - 2" file under "Other new or changed components". What they
tell you there is that you need to use Network Software Selector (in the
Apple Extras folder, I think) to switch between OT and MacTCP.
What's that invisible file, you ask? Can you say NSS == Extensions Manager
(as an application) for TCP/IP utilities??? That invisible document was
your old copy of MacTCP with its Type changed to keep it from loading as a
CP or extension.
I admit that the only reason I found this is that I was PO'd that I "didn't
have" OT 1.1 after the install. Since I didn't have it anywhere before, the
installer put it in as the invisible file, leaving MacTCP as the active
component. Once I read part of the Read Me file and launched NSS and
selected OT, I did have to open the TCP/IP control panel (the OT equivalent
of the MacTCP cp) and set the "connect via:" and "configure:" popups for
PPP and set by server. NSS did transfer all my gateway and DNS info
automatically.
The only problem I've had so far is that Netscape 1.12 crashed hard at some
point claiming something about a disconnected socket. I've never seen that
error before.
For me, this has been the smoothest system update in years. And I'm using
APS Powertools 3.6 for the driver of my Apple issue drive because I
couldn't get the Apple formatter to give me automounting partitions.
Dave
Dave Reiser
[email protected]
Date: Wed, 20 Mar 1996 02:02:33 +0100
Subject: System 7.5.3 where to get it
At 7:17 AM 19/3/96, The Info-Mac Moderators wrote:
> [email protected] (Dr. Leo G. Leduc)
Hi I've mirrored the System 7.5.3 update on my FTP site at:
cheers!
david
Date: Wed, 20 Mar 96 09:34:31 CST
Subject: System 7.5.3 won't work with my LCIII
Despite successfully updating a Quadra 800, PowerBook 520 and 2 PowerMac 8100's
at work, I can't get my LCIII at home to work with 7.5.3.
System
LC III 12 MB RAM, 768K VRAM
internal 80 MB HD, external 170 LaCie ZFP, 540 APS HD
CD 600e
Zip Drive
Apple Portrait monitor on built-in video
NEC 2V Multisync on DoubleColor LC PDS card
Booting gets me to the desktop pattern and an empty menu bar (clock only)--no
Apple menu, no other menus, no disks, no windows.
Shift-booting gets me to the desktop normally...
however, when I removed all CDevs, extensions, inits, DAs, etc., I still booted
to the empty menu bar.
Force-quitting gets me to the desktop, but this is, obviously, a less than
ideal
situation.
I installed the update on a "virgin" copy of 7.5 on the APS drive, with the
same
results.
I reformatted the 80 MB internal, reinstalled 7.5, updated it, same problem.
Also, copies (even SCSI to SCSI) are tremendously slow. My Apple II+ goes
faster
I've updated the HD drivers (HDSC setup on the internal, APS PowerTools 4.0 on
the externals), checked for viruses, burned incense, all to no avail. Any help,
posted here or via email would be much appreciated.
Steve
Date: Tue, 19 Mar 96 16:52:06 -0600
Subject: What's the Skinny on SoftWin 3/95?
>MacWarehouse tossed me a new catalog inviting me to drop another kilobuck
>to upgrade SoftWindows 2.0 to SW 3.0, or, better yet, SoftWindows95.
>Oddly, I haven't heard a peep about these newborn puppies, not even from
>the Apple press releases and Guy Kawasaki's EvangeList :-)
>Anyone know (besides the obvious--that they are optimized for the running
>of Windoze95) what these packages have to offer that SW-2 doesn't got?
My MUG saw a demo of SW3 at our monthly meeting a week ago. Its official
announcement came a couple of days later.
SW3 is supposed to be circa 30% faster than SW2. SW95 is SW3 with a copy
of Win95 thrown in *instead of* a copy of Win311; it allegedly runs Win95
about as fast as SW2 did Win311. It will also require more RAM, just as
Win95 does on a PC, and it's more expensive.
Bottom line: don't hamper yourself with SW95 unless you need to run apps
that require Win95/WIn32, and hence won't work under SW3. As an upgrade
>From SW2, SW3 sounds like a good idea.
Lanny Chambers ([email protected])
Creative Services, St. Louis, USA
Visit the Hummingbird Page at:
Date: Wed, 20 Mar 1996 14:07:43 -0500
Subject: what is a listserv for the ietf...
I am interested in getting the names of listservs in networking. Could
anyone suggest some to me? Thank you in advance
MBL
Date: Tue, 19 Mar 96 15:09:03 -0500
Subject: Win '95 on DOS compatibility card
>An Apple technician told me today that "lot's of people" are using Win
>'95 on their DOS compatibility cards (I've got a Performa 640 CD). Is
>this true?
I'm running it on the 6100/66 card (more or less the same as the 640 card
I think) and from traffic I've seen on the Net, I'd say it's not unusual
at this point. Be sure to get the CD upgrade, though; the floppy version
won't install on the card.
>Can anyone confirm this? The last time I asked an Apple tech
>about this (2 or 3 short months ago) I got a vague "we're thinking about
>it"-type response.
Basic operation is fine, except for clipboard transfer, which no longer
works. To really make optimal use of W95, though, Apple will have to
rewrite some drivers -- maybe that's what they're still thinking about
(along with enhancements to tcp support and a fix for the clipboard
transfer problem).
rs/[email protected]
Date: Tue, 19 Mar 1996 10:38:01 PST
I have a similar question about running NT on my DOS card, so I would like
to hear from anyone who has done this successfully.
Stephen W. Smoliar ([email protected]); FX Palo Alto Laboratory
3400 Hillview Avenue, Building 4; Palo Alto, California 94304
UNITED STATES; Tel: +1-415-813-6703; FAX: +1-415-813-7081
Date: Tue, 19 Mar 1996 18:57:01 +0000
Does anyone know where to find a Hebrew langauge program?
--Info-Mac-Digest--
