EjectDisk 3.2 - Eject disks of all types with a single key!
Download: http://archive.info-mac.org/cfg/eject-disk-32.hqx
EjectDisk is an extremely useful utility. With the touch of a key you can eject any removable media from your computer, ranging from the humble floppy to the latest DVD. You can even open and close the CD/DVD tray, and automatically eject a CD at shutdown. EjectDisk is similar to the Command-Y function of the Finder in function only--unlike that command, EjectDisk can evict storage from your desktop from within any program, and you don't have to select the disk beforehand.
EjectDisk 3.2 adds support for a number of CD-ROM drives which EjectDisk failed to work with in the past. It also increases the number of drives you can individually specify (from 4 to 12), and fixes a bug which could cause EjectDisk to miss disks when ejecting all disks of a particular type.
