Eject-Me-Not 1.0 - Stop ghosted ejected disks
Download: http://archive.info-mac.org/cfg/eject-me-not-10.hqx
Eject-Me-Not 1.0
Eject-Me-Not is an extension that disables the Finder's "Eject" command
and "steers" users toward the proper use of the "Put Away" command for
removing floppy disks (and other removables).
The use of the Special->Eject command or the command-E equivalent will
produce a dialog box explaining the "proper" method for ejecting disks
(and makes the user do it if they want to get their disk out!)
Requirements
A MacOS compatible computer System 7 or greater (a color monitor set for
at least 256 colors if you don't want the dialog box to be ugly)
Shareware: $10 - Site License $100 ($50 for educational institutions)
Eject-Me-Not may be distributed on shareware collections.
Paul Messias Park Bench Software http://www.parkbenchsoftware.com/
