Adds key commands for trash, restart, sleep
and many other features.
Current version: Finder 8.5 Patch 1.1
The new version fixes some conflicts and adds some new enhancements.
Included are five files, which are the Finder 8.5 Patch 1.1 and a revert
to original Finder Patch and three ReadMe files.
All files have been virus checked with SAM 4.5.
This shareware may be included on any CD without further permission.
