FinderKiller v1.0
FinderKiller v1.0
Download: http://archive.info-mac.org/cfg/finder-killer-10.hqx
FinderKiller is a simple AppleScript application without interface that
does one job. This AppleScript will quit the Finder, and nothing more.
This is a real simple script that you might find handy. This is part of a
series of small, quit and reset the Finder scripts that I wrote on
request. If you quit the Finder with no other applications running, the
Finder will automatically re-launch itself. This script does no checking
to see if anything else is running, and will not explicity attempt to
re-launch the Finder.
System requirements:
* OS 8, but will probably run on System 7.x with AppleScript and the
scriptable Finder
For more information, please read the included ReadMe file or check my
web site:
http://www.inch.com/~tjb/adoor.html
Thanks
Tom
