folder-builder-1.3.cpt
Download: http://archive.info-mac.org/cfg/folder-builder-13.hqx
FolderBuilder 1.3:
FolderBuilder, a publishing/archiving helper utility for MacOS, allows you
to automatically create dated, hierarchical folders. Great for
organizing/archiving date specific material! Before FolderBuilder, I used
to have to type in goofy leading characters on the filenames of my dated
archiving folders so they would sort properly. It took a while to create
the folders by hand and type in filenames. Regardless of how careful I was,
I'd always get a few typographical errors. Since I was creating a digital
archive that will probably outlive me, this was unacceptable. I was
frustrated. So, I developed a tool to solve the problem -- FolderBuilder.
Thanks!
Jim Johnson
Pixel8 Softworks
