Get Item Info Strip 1.0
Download: http://archive.info-mac.org/cfg/get-info-strip-10.hqx
This control strip module allows you to simply set the informations on
one or more file at ONE time!
For example, you may set the kind of the selection to Stuffit Archive,
modify the creation date of many files, set the Finder and resources
flags... Just with one clic!
Runs on any Macintosh with a control strip.
The shareware fee is payable via Kagi.
Firewalker
http://firewalker.home.ml.org
