Hi all : )
Please help - I've recently upgraded to Leopard from Tiger
and am using a G4 mirror door. The USB speedtouch modem
I was using no longer seems to be compatible with leopard : (
So I'm thinking of buying an 'original' airport card so I can connect
to my dads wireless router. Does anyone know if the 'original' airport
card is compatible with leopard?
Any info would be much appreciated.
Internet connection with G4 using Leopard
applebobbin
- 1 MB
Re: Internet connection with G4 using Leopard
Yes, it is compatible.
